2 registered members (cmw007, Jluff), 22 guests, and 5 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,102
Members8,546
Most Online117
Jan 16th, 2020
#489 - 05/30/10 10:20 PM OTIS FAULT MANUAL
ELEVATOR_TECH Offline
Hello friends i have a problem with an otis elevator i dont have plans and no manual for service tool but i would like to know if someone can help me with a list of the meaning of faults if there is one....or if u can send me information about it that would be really helpfull i hope u people can do it,
i really apreciateit.
hope to knw about u soon
RAFAEL DESDE VENEZUELA
#490 - 05/31/10 04:19 PM Re: OTIS FAULT MANUAL [Re: ELEVATOR_TECH]
Administrator Offline
Orange County, California
What is the model number of the controller you are working on? Is it a 211 or 411? What kind of failures are you having?
#491 - 05/31/10 09:52 PM Re: OTIS FAULT MANUAL [Re: Administrator]
wow i dont really know exactly cause we dont have plans and we dont found them...i have some pictures of controller if there is a way to send u i could.
when i use service tool on it! it says:
STM POWER FAIL
2002 ---> SHUTDOWN
but as we dont have manual of faults we dont know what does 2002 means u understand what i mean.
and when i try to set doors the say EMERGENCY STOP
Could u help me on this?
#492 - 05/31/10 09:59 PM Re: OTIS FAULT MANUAL [Re: ELEVATOR_TECH]
we need to know the meaning of numbers codes like 2002 to look for the problem at the elevator.
#493 - 06/01/10 04:18 AM Re: OTIS FAULT MANUAL [Re: ELEVATOR_TECH]
J Sand Offline
Troubleshooter
J Sand  Offline
Troubleshooter
Los Angeles
you have an SVT but no documentation? Am I correct you are not with an Otis company? Otherwise all of this is readily available. What type of controller? Hydro, geared or gearless? The fault code you gave is a generic code that always comes up when you POR the controller. Do you have more info?
#494 - 06/01/10 01:33 PM Re: OTIS FAULT MANUAL [Re: J Sand]
Yes thats the problem i have no documentation! and we dont work with otis company. i dont know how to find documentation on internet... it is geared. What does POR means? i have pictures and i know that there is a display in the controller that says 0--- i know the 0 means that one security is open but i dont have plans and no information i cant not look for it manually and activate it again! If there is a way to send u pictures of controller that would be nice! if u can help me in something i will apreciate this.
thank u very much
rafa
#495 - 06/01/10 04:17 PM Re: OTIS FAULT MANUAL [Re: ELEVATOR_TECH]
And what kind of info do u need? ill check the control and send info.....
#496 - 06/01/10 04:37 PM Re: OTIS FAULT MANUAL [Re: ELEVATOR_TECH]
We need plans of circuit of security of that elevator....? do u have it!!!!? or can someone help us!
#501 - 06/04/10 03:40 AM Re: OTIS FAULT MANUAL [Re: ELEVATOR_TECH]
If you need the job drawings you should call Unitech with the actual Job #. They can usually provide the correct prints for any job. You should post a picture in the photo gallery of the equipment that you are working on so people can help you with identifying your controller.
#505 - 06/04/10 04:07 PM Re: OTIS FAULT MANUAL [Re: Administrator]
HERE IS THE LINK OF THE PICTURE CONTROLLER
http://www.vatortrader.com/forums/gallery/3/full/75.jpg
#512 - 06/07/10 03:14 PM Re: OTIS FAULT MANUAL [Re: ELEVATOR_TECH]
J Sand Offline
Troubleshooter
J Sand  Offline
Troubleshooter
Los Angeles
311M or GEM (Same Thing) geared AC Traction, I Motion Door 2 Door Op and Serial Fixtures
#513 - 06/08/10 07:38 PM Re: OTIS FAULT MANUAL [Re: J Sand]
aquadag Offline
elevator lifer
aquadag  Offline
elevator lifer
NYC
MRL otis is bad news
#514 - 06/08/10 07:39 PM Re: OTIS FAULT MANUAL [Re: aquadag]
aquadag Offline
elevator lifer
aquadag  Offline
elevator lifer
NYC
too many problems to list controller and doors is the usual Otis bullet proof stuff but the machine and motor are junk, basically throw away. If they have those nasty flat rubber cables that's even worse unless you had a master mechanic install. you can tell by the wear of the treads if your gonna have issues. I won't touch these things, Otis loses their ass on these so I can't imagine anyone else doing much better. I'm in the process of scanning my Big O manuals to PDF when I'm done I'll let everyone know. I won't post them but I will email them to you. I'm also scanning all my TK, Kone,and Schindler stuff. That will take at least another month as the printer I use takes awhile and is kinda pricey to do this.
#567 - 07/09/10 07:57 AM Re: OTIS FAULT MANUAL [Re: aquadag]
401PPT Offline
401PPT  Offline
Hey Mate, by the looks of that picture you have there an Otis 311 with the RCB and MCB boards on the right there. STM power fail is just a generic fault telling us that the lift has lost power for some reason and as a result has shutdown. If you scroll further through the fault log you will find other faults that should tell you why.
#12267 - 10/09/14 12:00 AM Re: OTIS FAULT MANUAL [Re: aquadag]
rscobb Offline
Rob/Sasha Cobb
rscobb  Offline
Rob/Sasha Cobb
Texas
Old Otis MRV Elevator... do you know about them and the fault codes?
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.045s Queries: 15 (0.008s) Memory: 2.7635 MB (Peak: 3.0085 MB) Zlib disabled. Server Time: 2024-06-16 00:24:29 UTC
