0 registered members (), 12 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,552
Posts37,032
Members8,546
Most Online117
Jan 16th, 2020
#11164 - 07/01/14 12:48 AM schindler 330A issue
mbke Offline
BSP
mbke  Offline
BSP
Hey bros of iuec. I have a 330A that will always get a 20 error with extra info 67.(possible PCT issue)always happens at the 3rd floor. I have changed the landing system , CRIP, and CIO board. CAP drain. Also made sure my UL Spring wasn't broken. Any body have anything on this?
MBKE
#11175 - 07/02/14 12:36 AM Re: schindler 330A issue [Re: mbke]
jkh  Offline
You may want to check your leveling. I usually set it for 5 to 6 seconds! If the time is too great it can trip those errors.
#11235 - 07/06/14 02:31 AM Re: schindler 330A issue [Re: jkh]
mrhappy Offline
mrhappy  Offline
is 3rd floor the top landing? if so,schindler may want to park the car above the floor by an inch on a relevel to reduce the number of times it relevels. otis does this and it means the up normal is set to low. the 20 fault with a 67 is relevel stall for more than 7 seconds. try cracking manual lowering while parked at that floor and see if it faults.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.024s Queries: 15 (0.005s) Memory: 2.6664 MB (Peak: 2.8089 MB) Zlib disabled. Server Time: 2024-06-06 12:24:23 UTC
