0 registered members (), 23 guests, and 3 spiders.
May
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
vacheera, KM Elevator, Shawzee, ChurchGuy, Luis Mariano
8461 Registered Users
Topics6,539
Posts36,981
Members8,461
Most Online117
Jan 16th, 2020
#11778 - 08/14/14 01:49 AM 400a fault 0067 Schindler
elevatorpat Offline
elevatorpat  Offline
Florida
Hi everyone
We are having the below issue with this car:
1- we have a 400a that is down right now. We had a ton of info on the job but it is all disappeared. We have fault 0067 which shows KUET fault. It says to check RUET and RUET1 relays and says they should be firing in tandem and also not in tandem which I don't understand. I can find RUET relay but can't find RUET1 relay. Where is it?
Our symptoms are this- we just took it over from schindler. Went to perform a test today and as soon as we put it on ph 1 fire service the car came down doors wouldn't open. Went to the controller and found a blown fuse (s1e I believe) it is rated for 4a but had a 2a in it. We replaced that and now we can run the car on inspection but when try to run on automatic the call latches the brake picks drive kicks on but car doesn't move. Then after a few seconds we get fault 0067.
This car was running fine until we tested fire service than BAM! The wiring on this thing is a mess, boards hanging out, inspector who passed it lost his license here in FLA (this part is me just venting now!!!)
Got any suggestions? Got any manuals or write ups for this?
#11796 - 08/16/14 02:01 AM Re: 400a fault 0067 Schindler [Re: elevatorpat]
NOTIME Offline
NOTIME  Offline
Check Traveling Cable
check in the print the LONIO for the Landing system
check the landing system
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.063s Queries: 15 (0.019s) Memory: 2.6614 MB (Peak: 2.7940 MB) Zlib disabled. Server Time: 2024-05-29 06:24:55 UTC
