0 registered members (), 24 guests, and 0 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,549
Posts37,012
Members8,546
Most Online117
Jan 16th, 2020
#13543 - 03/03/15 09:14 PM imem controller
karl barker Offline
karl barker  Offline
hi I have been working on an imem controller in fails and displays cc40 does banyone know what this means I have been told maybe brake ?
#13545 - 03/03/15 09:24 PM Re: imem controller [Re: karl barker]
jkh  Offline
Karl,
All I know is they are out of Spain...
#13554 - 03/05/15 07:43 AM Re: imem controller [Re: jkh]
ThyssenKrapp Offline
GDB
GDB
Its the monitoring circuit
check NC on main relays, brake switches and the UCM solenoid mounted on the govenor is the one that usually plays up
#13556 - 03/05/15 12:57 PM Re: imem controller [Re: ThyssenKrapp]
uppo72 Offline
uppo72  Offline
Cant quite remember the codes(there are leds to check for safety circuits, doors etc), but the can bus resistance is critical to normal operation. They seem to be very flighty, so check your resistors at the end of the serial buses and its ohmage. I think about 70 ohms is about right(from memory). Also as a safety flag, you can short out ALL of the locks via the main pcb with 1 wire(there seem to be no monitor between doors). Its handy when needing to bump the lift but dangerous if forgotten.
#13563 - 03/05/15 09:08 PM Re: imem controller [Re: ThyssenKrapp]
karl barker Offline
karl barker  Offline
ok thanks I have replaced main contactors alresdy so that eliminated, I am told the brake switches are incorporated within the brake and you have to replace the whole brake unit so I will check the ucm on govenor first thanks for info
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.052s Queries: 15 (0.006s) Memory: 2.6833 MB (Peak: 2.8426 MB) Zlib disabled. Server Time: 2024-06-01 11:05:25 UTC
