0 registered members (),
spiders. |
Topics6,556
Posts37,046
Members8,546
Most Online117 Jan 16th, 2020
#14488 - 06/19/15 11:57 PM
Re: Infrared Edge
[Re: bilys22]
ABE
#14489 - 06/20/15 12:07 AM
Re: Infrared Edge
[Re: ABE]
ABE
#14493 - 06/20/15 04:11 AM
Re: Infrared Edge
[Re: NewMech]
Vatorgator
they are probably right, they can't get that "exact" edge. however there are many edges on the market that will do the same job. If they really wanted to keep you as a customer, and make you happy with there service, then they would spend the relatively small amount of money and have the service guy install it and be done with it. that is what our company would do. since they have the obsolescence clause in your contract, they will probably stick to there guns. just be aware, that all the circuitry for the unit is already there, and swapping the existing edge for a newer edge is not a big job. pay attention to the proposal, it should not be an exorbitant amount of money to install. usually if you replace a mechanical edge with a infrared edge, then you can expect to pay a full day to install, and wire in the correct nudging, and fire service circuit upgrades, this can run 2000-3000 dollars, or more, depending on the company. However just replacing a infrared edge with another infrared edge should take 2-3 hours max. good detector edge 300 dollars, couple hours to install at 270 per hour, you should be paying around 900 maybe a little less if you get a little cheaper edge and the hourly rate a little lower. good luck, if your in the los angeles area, pm me and i can get you with a reputable company that won't nickel and dime you to death.
#14505 - 06/20/15 06:01 PM
Re: Infrared Edge
[Re: bilys22]
Vatorgator
like i said before, if they had to make appropriate changes for nudging and fire service etc, then this would be a close price, however changing a edge for an edge, this is way to much. even if they sent a team to do the job, which is 2 men, probably around 500 an hour, and the edge, probably around 400 with there 30% markup, that should only take 2 hours on the job, give them an hour drive time, now you are up to 3 hours x 500 , 1500 plus the edge 400, = 1900. personally i think that is excessive, as a single man can usually replace the edge, just my 2 cents what it is worth, but 3750 for an edge. ouch.
