0 registered members (), 13 guests, and 4 spiders.
May
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
vacheera, KM Elevator, Shawzee, ChurchGuy, Luis Mariano
8461 Registered Users
Topics6,539
Posts36,981
Members8,461
Most Online117
Jan 16th, 2020
#14867 - 08/20/15 12:54 AM Installing Maxton on an old Otis
VerticalTechNY Offline
Does anyone have a wiring diagram or cheat sheet for putting a Maxton valve on an older Otis that didn't use two up valves.
#14868 - 08/20/15 01:02 AM Re: Installing Maxton on an old Otis [Re: VerticalTechNY]
GreenPants Offline
GreenPants  Offline
The cheat is wire both valves in parallel to run up full speed and leave it as a down leveling unit. Thats how it was installed originally why change it now.
#14869 - 08/20/15 01:04 AM Re: Installing Maxton on an old Otis [Re: GreenPants]
Was trying to see if maybe there was an easy way to make up leveling work to make the ride a little better as a bonus.
#14870 - 08/20/15 01:08 AM Re: Installing Maxton on an old Otis [Re: VerticalTechNY]
GreenPants Offline
GreenPants  Offline
It is a pain, you have to add switches in the hoist way and leveling relays. The Maxton is more stable, if you adjust the valve right it will be much smoother than the old valve and barley noticeable as a down leveling unit.
#14871 - 08/20/15 01:25 AM Re: Installing Maxton on an old Otis [Re: GreenPants]
Yeah, its been awhile since I did one of these old 3 coil Otis conversions. This thing will still be a lot nicer than what it was with the Maxton and soft starter. Thanks.
#14872 - 08/20/15 01:28 AM Re: Installing Maxton on an old Otis [Re: VerticalTechNY]
Only screw up was that Unitec built the new power unit using the sales number and everything was correct except for the valve solenoids came 120vac and were supposed to be 120vdc. My bad as I assumed (we all know what happens when you assume) that Unitec/Otis using their own original build info would get the coils right and I never checked it on the quote. I checked everything else but that. Luckily I had four of them.
#14875 - 08/20/15 02:38 AM Re: Installing Maxton on an old Otis [Re: VerticalTechNY]
Rolly Offline
Rolly  Offline
I agree with Greenpants. Either do as he says or Mod it. Way to much gingerbread and liability for your own design.
#15067 - 09/17/15 07:46 PM Re: Installing Maxton on an old Otis [Re: Rolly]
Justintime Offline
Justintime  Offline
If it were a 2 stop you could do it very easily by adding a slowdown switch that will drop out your high speed cool......more than two stops and I agree with the recommendation to change the controller
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.088s Queries: 15 (0.034s) Memory: 2.7063 MB (Peak: 2.8885 MB) Zlib disabled. Server Time: 2024-05-29 03:20:02 UTC
