0 registered members (), 12 guests, and 0 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,550
Posts37,017
Members8,546
Most Online117
Jan 16th, 2020
#15872 - 01/15/16 06:02 PM Gen 2 won't clear fire service
ridevertical Offline
I'm working on a gen2 that won't clear fire service. All inputs from devices appear correct. Runs fine on ph2, just won't reset. Any ideas?
#15875 - 01/16/16 09:44 AM Re: Gen 2 won't clear fire service [Re: ridevertical]
Alex75 Offline
Alex75  Offline
Sweden
GECB/TCB(C) Status menu shows what? (M-1-1-1)
#15878 - 01/16/16 03:02 PM Re: Gen 2 won't clear fire service [Re: Alex75]
Magic smoke Offline
Shaking the Bush!!
Magic smoke  Offline
Shaking the Bush!!
On a Boat!
Won't reset from the keyswitch or from the service tool? Do you have a fire panel keyswitch or a remote fire service keyswitch? Check for that input?
#15879 - 01/16/16 04:56 PM Re: Gen 2 won't clear fire service [Re: Magic smoke]
Alex75 Offline
Alex75  Offline
Sweden
it might be the parameter EFO-EX, that is set to only allow Phase 2 of the Fireman opration to end at the EFO floor (Where the EFS keyswitch is located). If you get the sequence wrong, it can be real murder to get it running again.
#15883 - 01/17/16 12:55 AM Re: Gen 2 won't clear fire service [Re: Alex75]
Vatorgator Offline
Vatorgator  Offline
did you try the pf ram reset, worth a try
#15915 - 01/21/16 12:52 AM Re: Gen 2 won't clear fire service [Re: ridevertical]
Hotsauce Offline
Hotsauce  Offline
Wash D.C.
Had the exact same issue a month or so ago. Don't still have the issue do you?
#15969 - 01/26/16 10:21 PM Re: Gen 2 won't clear fire service [Re: Hotsauce]
Still haven't cleared it yet. I don't believe my service tool is interfacing properly. It's a late model gen2 and my service tool is a couple years old. I tested my tool on another unit on my route and it works fine.Is there a way to do a hard reset w/o using the tool?
#15973 - 01/27/16 01:35 AM Re: Gen 2 won't clear fire service [Re: ridevertical]
Rolly Offline
Rolly  Offline
What happens if you tell it that it has NO fire service? Then POR.
#15975 - 01/27/16 04:46 AM Re: Gen 2 won't clear fire service [Re: Rolly]
NewMech Offline
NewMech  Offline
Get the car at the recall landing with the doors open, turn the key in the hall station to reset and then off. PF ram reset is M-1-5-1.What type of Gen2 controller do you have? 311 with an MLB or GCS?
#15981 - 01/27/16 03:57 PM Re: Gen 2 won't clear fire service [Re: NewMech]
CM1981 Offline
Mechanic/Supervisor
CM1981  Offline
Mechanic/Supervisor
Texas
I had a TXR5 that did the same thing at a plant. They had no key switches though and no smokes. It was the craziest thing is every seen. I even manually jumped the ports to make the I/Os come hi to low in the sequence the key switch would go and never got it cleared. Sold them a Smartrise Mod over that deal is how I fixed it.
#15997 - 01/29/16 04:54 AM Re: Gen 2 won't clear fire service [Re: CM1981]
Magic smoke Offline
Shaking the Bush!!
Magic smoke  Offline
Shaking the Bush!!
On a Boat!
C1RS, C5RS
#15998 - 01/29/16 04:55 AM Re: Gen 2 won't clear fire service [Re: Magic smoke]
Magic smoke Offline
Shaking the Bush!!
Magic smoke  Offline
Shaking the Bush!!
On a Boat!
Any new info?
#16341 - 03/04/16 12:47 AM Re: Gen 2 won't clear fire service [Re: Magic smoke]
Hey guys, sorry I didn't respond sooner. The tool I was using wasn't working right. I tried a different service tool and performed the pf RAM reset and I'm back in business. Thanks for all of the advice.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.033s Queries: 15 (0.008s) Memory: 2.7478 MB (Peak: 2.9748 MB) Zlib disabled. Server Time: 2024-06-04 04:22:30 UTC
