0 registered members (),
spiders. |
Topics6,561
Posts37,102
Members8,546
Most Online117 Jan 16th, 2020
#1108 - 01/29/11 04:18 AM
Re: KCM 831 Hydro
[Re: fateinc2005]
Scott Davidson
troubleshooter1
troubleshooter1
california
77:N is down NTS deceleration switch, according to the manual, this fault will auto recover as fateinc2005 indicates. this indicates you are missing the down nts signal while coming into the bottom floor. I have not worked on this equipment, but i would think it would log the fault and reset, then run in the up direction ok. but i guess if you run up and the down nts switch fails to come back on maybe that would cause you to fault again. it looks like the signal 77:n comes from the Car 61 bar reader, to the 806 lceccbn board, then to the lce 385 drv board, then to the 375 LCE cpu board. to test, compare the voltage on xc11-7 connector on the 375 LCE board which is the 77:U or up nts switch, and the xc11-8 connector on the 375 LCE board which is down switch, if car is in middle of hatch, both of these signals should read 0vdc with respect to ground, I believe, I could be wrong the switches may be open already in which case you would read 24vdc to ground. in any case they should be the same. if you run car down on inspect and pass the switch the voltage should change, compare up and down to check. if down switch is not changing then head to cartop and check switch in same manner.
#1128 - 01/31/11 02:24 AM
Re: KCM 831 Hydro
[Re: bill]
selfproclaimed
Big Apple
What other fault codes are you having? Are you having a F1 0053 or F1 0153 ? Scroll through the fault menu with the arrows and see what other faults are present.
#1137 - 02/02/11 12:32 AM
Re: KCM 831 Hydro
[Re: Esc Man]
selfproclaimed
Big Apple
Just be careful not to give it too much slop. When the proximity switches are set up they have to be 3/8 of an inch away from the magnets. To much play and you might get faults
#1375 - 04/27/11 04:56 AM
Re: KCM 831 Hydro
[Re: bill]
orange county, CA
The accpeted policy is to do an ADON learn run, and a shaft learn run, every 6 months. Also, on a KCM831 hydro, if you adjust the valve, you must do a shaft learn run again, because it records the "S-curve" velocities, even though the valve is only 2-speed.
Do you have the newer ADON board, the one with like 40 leds' on it, with each labeled as to function, and the white relays, -OR-, do you have the older one, with the clear case relays, and very few LEDs? The ADON 1 board is superceded, for good reason, not supported any longer, and the ADON 2 board is much more reliable.
