0 registered members (),
spiders. |
Topics6,549
Posts37,014
Members8,546
Most Online117 Jan 16th, 2020
#16921 - 04/30/16 01:41 AM
Re: Otis Gen2 SHD2700 shutdown code
[Re: Sevag]
Vatorgator
if you have a ovf30 drive, there is a setting in the drive menu to tell the controller if there is a brake switch or not. you can turn it off temporarily to test your switches without the nuisance shutdowns. we tried to get a switch also, and they only sell the entire brake assy. 15k unbelievable why won't they just sell the dam switch. we ended up getting one from a otis friend. more then one way to skin a cat. ha ha do you know which switch is causing the problem? we were having intermittent problems and could not determine which switch was problem, so here is what we did we removed one brake switch input to controller, and then jumped input to the other brake switch input at the controller, so one switch feeding both inputs. we then ran the car to see if it would fault, first time it did not, so reversed above circuit, and it faulted a couple hours later, that is how we determined which switch was the problem. however if you do this, and it continues to fail, the you have a problem with the brake actually picking. in which case 15 k might be needed ha ha
#16936 - 05/01/16 07:08 PM
[Re: Sevag]
Vatorgator
#17249 - 06/04/16 11:08 PM
[Re: Sevag]
Eric K
Pandoras Box?
Pandoras Box?
California
Working on the same fault. I was fortunate enough to watch the LED for the Emergency Brake sensor flicker while stopped with no demand. This one has the newer type of sensors (not optical).
When BE flickered for 30 seconds or so, it registered a brake state fault, remained parked at the floor for less than a minute, and then proceeded to answer my calls.
Hope that helps.
