0 registered members (), 22 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,095
Members8,546
Most Online117
Jan 16th, 2020
#17399 - 06/29/16 07:52 PM shindler 3300
hamdy nahas Offline
hamdy nahas  Offline
how can i use 3rd party access key card on shindler 3300
#17427 - 07/04/16 07:31 AM Re: shindler 3300 [Re: hamdy nahas]
ThyssenKrapp Offline
GDB
GDB
Just wire your card reader relay into the key switch on the cop and set it to a floor in the paremeters
#17431 - 07/06/16 12:10 AM Re: shindler 3300 [Re: ThyssenKrapp]
hamdy nahas Offline
hamdy nahas  Offline
Shindler 3300 has access called SASA
Cop doesn't has any key switch
how can i connect relay reader on cop and where
ThyssenKrapp @
#17446 - 07/08/16 01:42 PM Re: shindler 3300 [Re: hamdy nahas]
GDB
GDB
Take off the COP and find input X-KEY then use relay from card reader to input signal and assign to a floor in parameters
#17476 - 07/10/16 09:04 PM Re: shindler 3300 [Re: ThyssenKrapp]
hamdy nahas Offline
hamdy nahas  Offline
thanks alot ThyssenKrapp
if i want to make card reader for all input calls on COP
what should i do ?
#17483 - 07/11/16 03:20 PM Re: shindler 3300 [Re: hamdy nahas]
GDB
GDB
Either Buy the SAS system from Schindler or contact MODUSYSTEM and replace the COP with standard buttons using their driver board then you can do what you like with the calls
Would it not be easier to assign a pin code to all floors in the parameters using the existing software?
#17495 - 07/12/16 09:07 PM Re: shindler 3300 [Re: ThyssenKrapp]
hamdy nahas Offline
hamdy nahas  Offline
SAS system is very expensive
if i want to use 3rd party reader
what should i do?
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.035s Queries: 15 (0.015s) Memory: 2.6970 MB (Peak: 2.8725 MB) Zlib disabled. Server Time: 2024-06-13 22:16:57 UTC
