1 registered members (JJR),
spiders. |
Topics6,553
Posts37,033
Members8,546
Most Online117 Jan 16th, 2020
#17682 - 08/06/16 12:56 PM
tac 50 04
Jcjmowrey
Atlanta ga
The company I work for has recently picked up a contract with some tac 50 04's. Some of the UIT'S are disabled? The screens work and they display the cars direction, speed, and wether or not it's in the door zone buy the 4 buttons don't work. Is there a trick to enable these. I'm pretty sure I'll have to have the new version of IMS to do this and I'm working on getting that now from a company suggested on thus site. Once I get it is there a parameter like D26 that will enable the UIT.
#17687 - 08/07/16 04:53 AM
Re: tac 50 04
[Re: solidstate]
elmcannic
S. Central Utah
Jc, Until you become a bit more familiar with any Thyssen TAC whatever, be certain of what commands you enter into an UIT or through IMS. D26 is not related to the UIT operation. What your saying is, on the screen, it shows Door Zone, Speed, Direction etc., but when you press the up button, or down button once, the screen doesn't prompt you for the password? It doesn't change state at all? And yes, if the equipment is fairly recent TAC 50-04, you will have to have the latest IMS (9 pin comm cable. I think it's 9 anyway).
#17688 - 08/07/16 11:40 AM
Re: tac 50 04
[Re: elmcannic]
Jcjmowrey
Atlanta ga
I was just using D26 as an example. I've worked on many tac20s with the older version of ims and have also worked with the LON system on those as well. I've worked on a handful of tac 32's also, that don't have locked out UIT's, and have a manual for the 32's. I looked through the parameters in the 32 manual but can't find anything having to do with the UIT. I'm sure there is a parameter that will enable the UIT that isn't printed in manuals for the purpose of putting people like me in this situation.
#17689 - 08/07/16 12:07 PM
Re: tac 50 04
[Re: Jcjmowrey]
Jcjmowrey
Atlanta ga
I also think it's funny they claim their controllers are non-proprietary when they have a Uit, but then they disable the UIT on their way out the door???
#17693 - 08/07/16 10:08 PM
Re: tac 50 04
[Re: ABE]
Jcjmowrey
Atlanta ga
The building has IMS but it is only for the owners to monitor and change security locked out floors. And yes I'm probably wrong about the non-proprietary claim. One of these units does have a UIT that works just like one on a tac32 where you have to enter 1234144 for the pin. The first time I went to this site this unit was down due to door disconnect, I had to change D26 to 0 and then WRT. I was lucky this wasn't the situation on the units with disabled UIT's. I do have the new version of ims installed on a laptop with Windows XP. The company I got it from emailed me the temporary site key yesterday. I'll be trying it out monday morning and let yall know if it works. After a week's free trial I have to by an unlimited site key for 1500 which is actually a good price if it works.
#17694 - 08/08/16 01:43 AM
Re: tac 50 04
[Re: Jcjmowrey]
Silly
I find this sort of thing amusing. As you claim all the UITs don't work, then you post the not so uber secret password on open forums. And you have the audacity to wonder why TKE would ever want to make it harderish kinda? Try taking the thumb drive, reading the manual, then get back to the forums with a real question that I will be thrilled to answer.
BTW the most common reason a UIT is inoperative is because it was swapped, or software was swapped. They are job specific so companies couldn't simply remove the UIT and take it as a service tool. I know, really weird TKE would have to worry about that sorta thing huh? Been with them for 16 years now and I do not know of any IMS parameter changes that can enable the UIT. Try reloading software but chances are these units got swapped at some point,
#17695 - 08/08/16 02:51 AM
Re: tac 50 04
[Re: Silly]
Jcjmowrey
Atlanta ga
Sorry about the wording earlier, 1 uit works the other 3 dont. Thanks for the info that there probably isn't a parameter that disables the uit. If they were swapped then it was done by tk. Hopefully not intentionally because I know a lot of tk guys and they are great guys and I don't think they would maliciously do something like that just because they lost a contract. I've fixed problems before by reading the manual and reloading software on tac 32's. This was easy because I was trained by tk on how to do this year's ago when the 32's just came out. It was not possible to try this the other day because all the backup thumb drives had been removed from the job before we took over. My question now would be if I make backup thumb drives with the existing software and try to reload will I just be replacing corrupt software with corrupt software?
#17701 - 08/09/16 01:01 PM
Re: tac 50 04
[Re: Silly]
Jcjmowrey
Atlanta ga
I just hooked up to a tac 50 04 with the new version of ims from liftware.ir and it works great
#17789 - 08/21/16 03:21 AM
Re: tac 50 04
[Re: Indirtwetrust]
Jcjmowrey
Atlanta ga
Yes, I'm using the same DB9 cable I use with tac 20's and it does work with the newer Ld03 operator boards via the cpua card.
