0 registered members (), 21 guests, and 4 spiders.
May
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
vacheera, KM Elevator, Shawzee, ChurchGuy, Luis Mariano
8461 Registered Users
Topics6,539
Posts36,981
Members8,461
Most Online117
Jan 16th, 2020
#18611 - 11/11/16 12:15 AM Elevonic 401
Ben Dover Offline
Ben Dover  Offline
Anyone had to micromanage an intermittent low line fault on a Robicon drive
#18614 - 11/11/16 02:34 AM Re: Elevonic 401 [Re: Ben Dover]
Rolly Offline
Rolly  Offline
What are you using to look at fault? I believe that is a very small transformer in the back of the controller. Don't remember the name but it always caused a low line fault. Swap it with another car see if you move the problem.
#18616 - 11/11/16 04:11 AM Re: Elevonic 401 [Re: Rolly]
NewMech Offline
NewMech  Offline
Low line LED on the drive? I've seen that caused by drive board two.
#18617 - 11/11/16 04:54 AM Re: Elevonic 401 [Re: NewMech]
Ben Dover Offline
Ben Dover  Offline
It's an Otis 401 with a Robicon direct drive and it has a control board with fault leds. The low line led comes on once about every sixty or so runs. The processor resets the drive and it takes back off again. I've checked the supply and it is stable. Replaced the drive board and it is still happening.
#18620 - 11/11/16 06:13 AM Re: Elevonic 401 [Re: Ben Dover]
NewMech Offline
NewMech  Offline
Replaced the board or swapped with a known good? We've had boards come back from the board shop and still throw a low line.
#18639 - 11/13/16 06:28 PM Re: Elevonic 401 [Re: NewMech]
Ben Dover Offline
Ben Dover  Offline
Replaced with a known good one
#18734 - 11/20/16 04:36 PM Re: Elevonic 401 [Re: Ben Dover]
NYTECH Offline
NYTECH  Offline
Years ago I remember fixing this problem at Monte Fiore Hospital, Bronx NY. by adding a 2.2 micro fard capacitor to the input of the operational amplifier that senses the line volts, but I do not remember the details. NO REPAIR SHOP will realty know where to look unles they have one of those electronic techs with good background in control system that also understand the DRIVE circuit diagrams.
#18805 - 11/30/16 12:25 AM Re: Elevonic 401 [Re: NYTECH]
Ben Dover Offline
Ben Dover  Offline
Thanx I'll look into that.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.026s Queries: 13 (0.005s) Memory: 2.7089 MB (Peak: 2.8913 MB) Zlib disabled. Server Time: 2024-05-29 08:12:24 UTC
