1 registered members (Hayk), 16 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,549
Posts37,014
Members8,546
Most Online117
Jan 16th, 2020
#19466 - 02/07/17 02:43 AM TAC 20 (2003)
nvadorm Offline
nvatorm
nvadorm  Offline
nvatorm
I changed the packing on a tac 20 and left power off for 2 days b/c I had the wrong size and had to overnight the correct packing.
I finished the repack and turned power back on and the elevator:
1) will only run on inspect.
2) will level up or down to a floor but always about 2 inches low.
3) I swapped the selector with a known good
4) I swapped all the 24vdc & 110vac relays with the exception of the 12 at the bottom of the main controller board. (there are 12 and some of them control the valves)
I was told that the battery on the cpu may not have had enough power to hold the programming for 2 days, would this cause the problem I have? What else could it be?
#19470 - 02/07/17 04:34 AM Re: TAC 20 (2003) [Re: nvadorm]
nvadorm Offline
nvatorm
nvadorm  Offline
nvatorm
5) The elevator doors will sometimes open and then close slowly after the car levels down to the 1st landing when I take it off of inspect.
When I reset the door operator it usually does a learn run, but now it just opens and closes slowly once.
#19474 - 02/07/17 05:23 PM Re: TAC 20 (2003) [Re: nvadorm]
jkh  Offline
Are you using a service tool?
Did you create a job file?
When was the battery last changed?
What faults are shown on the tool?
#19477 - 02/08/17 12:17 AM Re: TAC 20 (2003) [Re: jkh]
Indirtwetrust Offline
Local 18
Does (2003) mean it was put in in 2003 or it's a TAC20-03?
You are really going to need IMS to get any further with this.
#19478 - 02/08/17 03:55 AM Re: TAC 20 (2003) [Re: Indirtwetrust]
nvadorm Offline
nvatorm
nvadorm  Offline
nvatorm
The 3v battery on the main control board wasn't making good contact. I spun it around to look at the model number and the elevator started working on automatic.
2003 was the installation year.
No service tool frown ... Although I would like to get one.
Where is the best place to get a service tool?
Vertical Express?
Anywhere else?
Will they only work for a specific job or specific elevator?
Do you have to renew them annually?
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.028s Queries: 15 (0.007s) Memory: 2.6835 MB (Peak: 2.8414 MB) Zlib disabled. Server Time: 2024-06-03 12:53:13 UTC
