1 registered members (NewMech), 14 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,097
Members8,546
Most Online117
Jan 16th, 2020
#22045 - 10/30/17 10:05 PM 330A Inspection issue!
mbke Offline
BSP
mbke  Offline
BSP
33OA . Says on inspection . But all my inspection switches on car top, in car station and in machine room ring out ok and are in the run position. Changed CRIP board, changed CIOACD 3.Q. Checked I/O'S under status JREC (car top, Inactive = OK), (JRECC ,in car inspection inactive = ok) Drained GCIO 360 Capacitor 15 min, to .0070 vdc.
AND GO.......
THANKS
MBKE
#22048 - 10/30/17 11:02 PM Re: 330A Inspection issue! [Re: mbke]
jkh  Offline
I wonder if it would change if you disconnect the wires at the cpu?
#22049 - 10/30/17 11:53 PM Re: 330A Inspection issue! [Re: jkh]
Indirtwetrust Online content
Indirtwetrust  Online Content
Local 18
#22050 - 10/31/17 02:00 AM Re: 330A Inspection issue! [Re: Indirtwetrust]
beaupeep Offline
beaupeep  Offline
ontario
Replace GCIO
#22051 - 10/31/17 03:21 AM Re: 330A Inspection issue! [Re: beaupeep]
elmcannic Offline
elmcannic  Offline
S. Central Utah
On some equipment, car door/hall door bypass switch if turned on when the car is on auto will issue an INSP command. Confusing as heck if you're not ready for it.
#22060 - 10/31/17 06:23 PM Re: 330A Inspection issue! [Re: elmcannic]
mbke Offline
BSP
mbke  Offline
BSP
CHANGED ALL INSPECTION KEY SWITCHES AND CAR TOP INSPECTION ROCKER. STILL NOTHING.... ORDERED NEW SOFTWARE 3.61
WE WILL SEE...
MBKE
#22082 - 11/01/17 05:15 PM Re: 330A Inspection issue! [Re: mbke]
mbke Offline
BSP
mbke  Offline
BSP
SOFTWARE CHANGE DID NOTHING. SAYING AT 3RD FLOOR.REALLY AT BASEMENT. ALL IN NORMAL POSITION. SAYS ON INS. 121X 6E FAULT. NEW SWITCH INSTALLED. STILL NOTHING...
MBKE
#22083 - 11/01/17 05:18 PM Re: 330A Inspection issue! [Re: mbke]
mbke Offline
BSP
mbke  Offline
BSP
SAYS MISMATCH ON CAR TOP INSPECTION SWITCH . NEW SWITCH AND THE FAULT STILL IS THERE
MBKE
#22112 - 11/04/17 02:17 AM Re: 330A Inspection issue! [Re: mbke]
Peter iuec Offline
Dumbguy=more$$$$
Peter iuec  Offline
Dumbguy=more$$$$
Canada
Replace GC10
#24019 - 05/22/18 06:06 PM Re: 330A Inspection issue! [Re: mbke]
ovideo04 Offline
ovideo04  Offline
Replace CIO board inside the COP with the same version.
#24020 - 05/22/18 10:15 PM Re: 330A Inspection issue! [Re: mbke]
Tamperprufe Offline
Tamperprufe  Offline
USA
GCIO
#25453 - 12/21/18 12:42 PM Re: 330A Inspection issue! [Re: mbke]
mbke Offline
BSP
mbke  Offline
BSP
Thanks guys , I found a broken wire on the CIOACD . All better. !
MBKE
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.030s Queries: 15 (0.007s) Memory: 2.7385 MB (Peak: 2.9572 MB) Zlib disabled. Server Time: 2024-06-14 00:09:56 UTC
