0 registered members (), 20 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,562
Posts37,108
Members8,546
Most Online117
Jan 16th, 2020
#22800 - 01/21/18 05:48 PM mce-imc. PR error (binary floor code )
JimboNJ Offline
JimboNJ  Offline
Nj-NYC
Hi guys. We get this error about every 48hrs on the 8th floor where it homes -15 stop car - changed tape guides and Pr sensor in LS-quad unit. - on 8th floor we have all 3 led's lit (rd-pr-r3) on controller ) even swapped triacs on leveling box (pr with the rd triac) and still no luck
#22802 - 01/21/18 07:58 PM Re: mce-imc. PR error (binary floor code ) [Re: JimboNJ]
Indirtwetrust Offline
Local 18
I’d probably replace the R3 sensor and triac too. I think if it went low it would throw that error since there would be an odd parity, same for another sensor failing closed. I’m sure you’ve checked the magnets at that floor, also check traveler and ribbon cables taking the signals from SCR-RI to DIO and DDP boards. Maybe wiggle connections while watching the inputs.
#22803 - 01/21/18 08:30 PM Re: mce-imc. PR error (binary floor code ) [Re: JimboNJ]
JimboNJ Offline
JimboNJ  Offline
Nj-NYC
Thank you !
#22805 - 01/22/18 12:37 AM Re: mce-imc. PR error (binary floor code ) [Re: JimboNJ]
JimboNJ Offline
JimboNJ  Offline
Nj-NYC
Forgot to mention that the P.I says 12 but car is always found at 8
#22810 - 01/23/18 12:25 AM Re: mce-imc. PR error (binary floor code ) [Re: JimboNJ]
UpandDown2321 Offline
It shouldnt be correct because of parity, but if it says 12 its possible R2 is an issue. As R3 and R2 would code floor 12 instead of 8
#22811 - 01/23/18 12:35 AM Re: mce-imc. PR error (binary floor code ) [Re: JimboNJ]
Local 18
Based on that, I think it’s extremely likely that R2 is the problem. Replace the sensor and triac!
#22845 - 01/26/18 12:49 AM Re: mce-imc. PR error (binary floor code ) [Re: JimboNJ]
JimboNJ Offline
JimboNJ  Offline
Nj-NYC
Thanks guys. Replaced r2 and R3 sensors and triacs -back in service
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.054s Queries: 15 (0.016s) Memory: 2.6989 MB (Peak: 2.8733 MB) Zlib disabled. Server Time: 2024-06-18 16:43:22 UTC
