0 registered members (), 15 guests, and 3 spiders.
May
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
vacheera, KM Elevator, Shawzee, ChurchGuy, Luis Mariano
8461 Registered Users
Topics6,535
Posts36,965
Members8,461
Most Online117
Jan 16th, 2020
#22869 - 01/31/18 12:05 PM KONE monospace V3f25 no input to brake module
bowser Offline
bowser  Offline
Auckland. New Zealand
Brake doesn't lift on KONE monospace. The input to the brake module which Im guessing tells the module to lift the brake does not change when driving on inspection or normal and we get error 0101.
This input comes from the LCECPU board via a ribbon cable. It is labelled 24v, 0v and control. It doesnt change state when we yry to run the lift. Has anyone experienced this?
#22889 - 01/31/18 10:07 PM Re: KONE monospace V3f25 no input to brake module [Re: bowser]
UpandDown2321 Offline
Sounds like it could be contact failure for PWM enable. 201:3 and 201:4 have contacts for that.
#22898 - 02/01/18 03:53 AM Re: KONE monospace V3f25 no input to brake module [Re: bowser]
heisenberg Offline
Engineer
heisenberg  Offline
Engineer
Could be faulty brake module, I've had to replace 2 of them.
#22903 - 02/01/18 11:03 AM Re: KONE monospace V3f25 no input to brake module [Re: bowser]
bowser Offline
bowser  Offline
We changed the brake module and its not that. The input to the brske module doesnt change.... the control is supposed to be grounded which enables the brake module to lift the brakes... but this input/output does not change.
#22905 - 02/01/18 05:55 PM Re: KONE monospace V3f25 no input to brake module [Re: bowser]
koneisland Offline
koneisland  Offline
Faulty CPU or ribbon cable ?
#22906 - 02/01/18 10:56 PM Re: KONE monospace V3f25 no input to brake module [Re: bowser]
bowser Offline
bowser  Offline
Its what Im thinking...
Have you had this before?
#22913 - 02/02/18 03:02 PM Re: KONE monospace V3f25 no input to brake module [Re: bowser]
bowser Offline
bowser  Offline
Was the main drive board. FYI
#22962 - 02/06/18 05:41 AM Re: KONE monospace V3f25 no input to brake module [Re: bowser]
heisenberg Offline
Engineer
heisenberg  Offline
Engineer
Dam, hope it wasn't too pricey! Glad you found the problem
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.033s Queries: 15 (0.009s) Memory: 2.7075 MB (Peak: 2.8919 MB) Zlib disabled. Server Time: 2024-05-23 10:13:15 UTC
