0 registered members (),
spiders. |
Topics6,549
Posts37,013
Members8,546
Most Online117 Jan 16th, 2020
#23861 - 04/26/18 06:44 PM
Re: Otis MCS 120 Hyd. with Bucher
[Re: Yus123]
Alex75
Sweden
Hi Yus123
Does the lift have a pawl device? If yes, try to disable the Anti Creep Device for testing purpose. Set parameter in LCB-II M1-3-1-4 (Drive parameters) ACD/UXT = 0 (Disabled).
/Alex
#23884 - 04/30/18 06:50 AM
[Re: Yus123]
Alex75
Sweden
Hi Yus123
It looks like the only things that can generate the DAR state is:
- Fault from the Bucher control (Is the relay on the Bucher Power Supply connected?, If yes try to bridge this relay). - Or one of these inputs have been active: OTS (Oil Temp Switch), PLS (Pressure Limit Switch), MPD (Motor Protection Device), THB (Thermo Contact).
/Alex
