0 registered members (), 17 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,103
Members8,546
Most Online117
Jan 16th, 2020
#1879 - 10/01/11 02:40 PM OTIS 211 problem
Bamf1070 Offline
Bamf1070  Offline
Florida
Have a shutdown OTIS 211 hydro in a Hotel. I'm not with OTIS and have no information on the job site. Here's what I do have:
1. Main Board LED window displays "STLU"
2. Flashing red leds on "RING" and "HRT" on main board.
Any help would be appreciated.
#1880 - 10/01/11 02:58 PM Re: OTIS 211 problem [Re: Bamf1070]
vince90605 Offline
vince90605  Offline
california
stall in the up direction (stlu)
#1881 - 10/01/11 03:10 PM Re: OTIS 211 problem [Re: vince90605]
Bamf1070 Offline
Bamf1070  Offline
Florida
The unit is sitting just below the bottom landing, is it possible that this unit tripped the low oil timer and is sitting on the bottom limit preventing just a re-set to bring it back on line. this would make sense since there is a college football team staying at this hotel right now....
#1882 - 10/02/11 03:52 AM Re: OTIS 211 problem [Re: Bamf1070]
uppo72 Offline
uppo72  Offline
is the fault on all the time? i would kick the lift(safely) above the bottom floor then reset the lift to see if it clears the fault.
#1942 - 10/13/11 02:53 PM Re: OTIS 211 problem [Re: uppo72]
beenthere Offline
beenthere  Offline
There were some adjustment issues on a string of Maxton valves where the unit would go into viscosity control and the elevator would creep up real slow generating the stlu fault. If I remember correctly decreasing the bypass pressure corrected this.
#1946 - 10/13/11 10:29 PM Re: OTIS 211 problem [Re: beenthere]
vince90605 Offline
vince90605  Offline
california
a "VALV" fault would indicate the valve problem. It happeneds when the car bypasses the oil to heat it up to temp during olt operation and the car moves out of the door zone because the valve is not adjusted properly. Like you said , i usually crack the bypass open half a turn and check it again to see if it clears the problem , rather than turn off the oil temp function.
#1948 - 10/14/11 02:19 AM Re: OTIS 211 problem [Re: vince90605]
sccjr Offline
Shootintrouble
sccjr  Offline
Shootintrouble
On that last post, if you add oil additive for a tight packing it will change the viscosity of the oil. If bypassed is not set correctly you will get a "valv" fault, the car will creep up through viscosity mode. As to your "stlu" fault check your upper limit switches there always on the edge, I think its The L4s sw.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.032s Queries: 15 (0.007s) Memory: 2.6989 MB (Peak: 2.8746 MB) Zlib disabled. Server Time: 2024-06-16 01:34:49 UTC
