0 registered members (), 12 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,549
Posts37,013
Members8,546
Most Online117
Jan 16th, 2020
#26752 - 04/26/19 01:40 PM Old OTIS - HOTSL
wltr00 Offline
wltr00  Offline
This timer for an older OTIS elevator has gone bad and can't find a replacement for it. Anyone ever come across this?
The timer block is labeled SP on the print. Is there an acceptable workaround or replacement part?
Please see the attached pictures.
Timer Circuit.jpg (32 downloads)
Timer Code.jpg (27 downloads)
#26754 - 04/26/19 02:41 PM Re: Old OTIS - HOTSL [Re: wltr00]
TC7 Offline
TC7  Offline
That is "Stall Protection" basically Low Oil or Pump Time whatever you prefer to call it . I have replaced these before with octal base plug in timer. I think SP is normally always picked. When PM or UVR pull in to run up, it starts timer. If it takes too long then SP time expires opening the path to ground (HL1) at terminal 2 on SP timer. You may need a timer and a spare relay to accomplish this. Basically design your own circuit, I'm not sure there is direct replacement from Unitec.
#26758 - 04/26/19 04:46 PM Re: Old OTIS - HOTSL [Re: wltr00]
Huskervator Offline
Huskervator  Offline
Adams A103C1
#26760 - 04/26/19 05:46 PM Re: Old OTIS - HOTSL [Re: wltr00]
Rolly Offline
Rolly  Offline
I have the exact timer you need. PM me an address and I will send you one. I have plenty.
#26761 - 04/26/19 06:04 PM Re: Old OTIS - HOTSL [Re: Rolly]
wltr00 Offline
wltr00  Offline
Thanks, Rolly. PM sent!
#26762 - 04/26/19 08:11 PM Re: Old OTIS - HOTSL [Re: wltr00]
Rolly Offline
Rolly  Offline
Timer is on the way, Tracking # in PM
#26764 - 04/26/19 11:15 PM Re: Old OTIS - HOTSL [Re: Rolly]
wltr00 Offline
wltr00  Offline
Thanks, Rolly!
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.022s Queries: 16 (0.005s) Memory: 2.6998 MB (Peak: 2.8808 MB) Zlib disabled. Server Time: 2024-06-02 12:03:32 UTC
