0 registered members (), 5 guests, and 0 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,549
Posts37,016
Members8,546
Most Online117
Jan 16th, 2020
#27304 - 07/02/19 05:35 AM HELP LIGHTS FOR LEV ELEVATOR
Norm7 Offline
Norm7  Offline
UPS SYSTEM DIED FOR SEVERAL MONTHS. NO LIGHTS OR ERROR CODES ON THE CONTROL BUTTON. HOWEVER CEILING LIGHTS IN ELEVATOR WERE ON. TURNED OFF BOTH CIRCUIT BREAKERS AND CEILING LIGHTS WERE STILL ON. LIGHT BULBS WERE UNSCREWED AND LEFT FOR ABOUT ANOTHER MONTH.
I REPLACED UPS, SCREWED LIGHT BULBS IN. ELEVATOR WORKS. CONTROL WORKS. BUT LIGHTS DO NOT. PUT IN NEW LIGHT BULBS AND RESET STILL EVERYTHING WORKS BUT THE LIGHTS.... TRIED SEVERAL TIMES I ALSO TURNED OFF SWITCHES FOR THE ELEVATOR AND LIGHTS THAT ARE ABOVE CAB, STILL THE LIGHTS DO NOT WORK. HELP!
#27326 - 07/03/19 11:28 PM Re: HELP LIGHTS FOR LEV ELEVATOR [Re: Norm7]
elmcannic Offline
elmcannic  Offline
S. Central Utah
Norm,
The cab lighting typically has three open or closed sources for cab lighting power.
First; The building breaker panel marked CAB LIGHTING or something like that.
Second; In the elevator equipment room, there will be yet another switch mounted on the wall or on the elevator control cabinet hopefully marked CAB LIGHTS.
Third; Inside the cab, there should be a switch marked “LIGHTS/ON/OFF. Be sure all sources are ON. If still nothing, I’m not sure what to tell you but it needs to be determined if power is actually getting to the cabin, and at that point I suggest you get in touch with a licensed elevator company. However if you’re the licensed mechanic, then it’s up to you to figure it out, and it isn’t that difficult. Cab power sources, if absent, and all indications are there should be power, are the building owners responsibility.
Good luck.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.023s Queries: 15 (0.008s) Memory: 2.6607 MB (Peak: 2.7928 MB) Zlib disabled. Server Time: 2024-06-04 02:08:37 UTC
