0 registered members (), 14 guests, and 0 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,562
Posts37,108
Members8,546
Most Online117
Jan 16th, 2020
#28371 - 12/03/19 04:14 PM Kone New Drive Hoistway learn
Hannibal Offline
Hannibal  Offline
Hi, i have the problem i change the drive to a new KDL16 but when i try do the learn of the hoistway nothing works.
i follow the instruccion of the paper that kone send but nothing works. Someone have this problem ?
#28376 - 12/03/19 08:40 PM Re: Kone New Drive Hoistway learn [Re: Hannibal]
Hannibal Offline
Hannibal  Offline
On menu 5-2-1 always say no floor.
#28378 - 12/04/19 12:32 AM Re: Kone New Drive Hoistway learn [Re: Hannibal]
LA Tech Offline
LA Tech  Offline
Local 18
61U, 30, 77N, 77S on. 61N 77U off. I assume you have a running car on inspection. What mode is 4-1 when you take car off insp. while trying to do shaft setup? Close end on door operator made up?
#30216 - 11/25/20 02:07 AM Re: Kone New Drive Hoistway learn [Re: Hannibal]
Jubril Offline
Jubril  Offline
If any engineer could please assist me on how to reprogram the floor numbering from the LON board...since then replacement of the board, the "G floor" is showing "1" while "3rd floor" displaying "4th" on KONE MONOSPACE
#30221 - 11/25/20 07:04 PM Re: Kone New Drive Hoistway learn [Re: Hannibal]
Jadam Offline
Jadam  Offline
Set all the drive parameters
Checking the load weighing device
Place the elevator under the bottom floor before making a shaft setup in rdf, then menu 5-2-1.. put the lift in normal mode and the elevator starts the setup driving up..
#30222 - 11/25/20 07:06 PM Re: Kone New Drive Hoistway learn [Re: Jubril]
Jadam Offline
Jadam  Offline
Jubril... check menu 3-1 and menu 3-2
#30229 - 11/27/20 06:03 PM Re: Kone New Drive Hoistway learn [Re: Jadam]
Jubril Offline
Jubril  Offline
@jadem, thank you very much. You're appreciated.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.026s Queries: 15 (0.007s) Memory: 2.6988 MB (Peak: 2.8722 MB) Zlib disabled. Server Time: 2024-06-18 00:57:50 UTC
