0 registered members (),
spiders. |
Topics6,535
Posts36,966
Members8,461
Most Online117 Jan 16th, 2020
#30969 - 04/13/21 11:15 PM
Re: Tac22 Fire Service fault
[Re: ZeroProxy]
Indirtwetrust
Local 18
Is FSC2 high in the car? And can you see the IOs change state in the group IO map? Also make sure there aren’t any other FSH IOs anywhere in the group. There could be IOs for a secondary fire service switch. Was the 188e replaced? If so were you able to get the job cfg file out of the old board to put in or was it an in-adjusted job file?
#30970 - 04/13/21 11:19 PM
[Re: ZeroProxy]
ZeroProxy
#30972 - 04/13/21 11:42 PM
[Re: Indirtwetrust]
ZeroProxy
Is FSC2 high in the car? And can you see the IOs change state in the group IO map? Also make sure there aren’t any other FSH IOs anywhere in the group. There could be IOs for a secondary fire service switch. Was the 188e replaced? If so were you able to get the job cfg file out of the old board to put in or was it an in-adjusted job file? Yes i can see the IOs switch on the group IOs and the car IOs, now that you mention it i do have FSH3 and FSH4 on the group IOs which are unused but they are there, the job as far as im aware shouldn't and doesn't have a secondary fire switch. the 188E was replaced before, I dont know if they got the cfg file (i wasnt on this area when that happened) out of the old board but i do know they used the job file from a CD. if i need to remove those IO can i do it through ims?
#30982 - 04/14/21 02:36 PM
[Re: Indirtwetrust]
ZeroProxy
Ya, just right click on the IO, click add or change an IO, delete the IO name. You won’t see the changes until you write it, reset the CPU, and reload the the network in the control panel. When I right click the IO the only options I get are: HELP on IO, metered logic, positive logic, display 8 bit ports, 16 bit ports, connect to virtual scope, hide show unused columns and enable IO injection I have IMS 2.4
#30989 - 04/14/21 08:50 PM
[Re: Indirtwetrust]
ZeroProxy
I managed to get it working, jumped FSH4 to G24 and the reset the fire service and it worked. Where can I get a newer version?
