0 registered members (), 16 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,564
Posts37,113
Members8,546
Most Online117
Jan 16th, 2020
#32498 - 02/08/22 02:18 AM Tac 50 DE input won’t go high
Upndown frank Offline
local 18(1988)
local 18(1988)
Orange california
I can’t get de input to go high car won’t run!!!!!!
#32499 - 02/08/22 05:20 PM Re: Tac 50 DE input won’t go high [Re: Upndown frank]
UpandDown2321 Offline
Some cars have a secondary gate switch. Check that I've seen that
#32500 - 02/08/22 05:22 PM Re: Tac 50 DE input won’t go high [Re: Upndown frank]
Otherwise more info would be needed. Changed DE module? Pico fuse for the module
#32501 - 02/08/22 08:35 PM Re: Tac 50 DE input won’t go high [Re: Upndown frank]
local 18(1988)
local 18(1988)
Orange california
I’ve gone thru gates and limit switches all my inputs for door circuit are working good did hyperterminal PMI cards test all a go I’m finding my drive isn’t firing up there for no 24 v getting to some off my inputs got 125 v going to drive but nothing is turning on I’m running out of ideas my drive is magnetek dsd412 I’m thinking drive might be bad . Any help appreciated thanks Frank
#32502 - 02/08/22 09:27 PM Re: Tac 50 DE input won’t go high [Re: Upndown frank]
It's possible the power supply is bad on the drive. The print should show where the 24v comes from
#32504 - 02/09/22 04:06 PM Re: Tac 50 DE input won’t go high [Re: Upndown frank]
local 18(1988)
local 18(1988)
Orange california
You are certainly correct me and my partner took drive apart and found bad power supply thankyou for the help buddy we will ordered new one today your awesome
#32596 - 02/22/22 02:21 PM Re: Tac 50 DE input won’t go high [Re: Upndown frank]
MLO Offline
EECO
MLO  Offline
EECO
MAINE
upndown frank, I have same issue. did you have the quantum drive? mine is ac and according to my books, its the quantum 10k.
I checked the 4 power supplies in the bottom right front and they all test good. did you find another power supply somewhere?
my next step is to do the low voltage test on the drive components. Caps, resistors etc.
#32598 - 02/22/22 04:53 PM Re: Tac 50 DE input won’t go high [Re: MLO]
local 18(1988)
local 18(1988)
Orange california
My drive was dsd412 scr drive not quantum drive but are power supply was in the drive not sure about quantum
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.039s Queries: 15 (0.006s) Memory: 2.7054 MB (Peak: 2.8892 MB) Zlib disabled. Server Time: 2024-06-18 22:23:32 UTC
