0 registered members (), 13 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,561
Posts37,103
Members8,546
Most Online117
Jan 16th, 2020
#32857 - 04/05/22 08:20 PM DMC-I Hall call Problem
M2RE Offline
Chilling
M2RE  Offline
Chilling
Hey guys, Recently had the CLC not working, it would turn On then right away off. Changed Power Supply and it started functioning properly, except the hall call circuit, which it would not hold the light. Car arrives but the light will be off the whole time. Happens at all hall stations. Checked fuses, “validate floor” parameter and car is the Master(Single 3stop). I also did 2 Hoistway setup. It does not happens in the car call, only hall up or down dont matter. Any suggestions?
#32858 - 04/05/22 09:50 PM Re: DMC-I Hall call Problem [Re: M2RE]
Johnny Offline
Johnny  Offline
Portland. Oregon
Wrong common??? Is this a new job, or an older one?? Is there 24vdc between the commons at the hall stations??
#32860 - 04/05/22 10:18 PM Re: DMC-I Hall call Problem [Re: M2RE]
Indirtwetrust Offline
Local 18
The toggle switch in the COP
#32863 - 04/05/22 10:29 PM Re: DMC-I Hall call Problem [Re: M2RE]
Local 18
Hall call common is P24G so the buttons light and call the car but the CLC outputs that latch the calls are powered from P24GS. S for Switched, after the 3 pole toggle switch.
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.032s Queries: 15 (0.007s) Memory: 2.6745 MB (Peak: 2.8259 MB) Zlib disabled. Server Time: 2024-06-17 08:42:46 UTC
