1 registered members (Ferns), 6 guests, and 2 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,549
Posts37,014
Members8,546
Most Online117
Jan 16th, 2020
Page 2 of 2 1 2
#7037 - 05/15/13 11:17 AM Re: 1922 Otis SOB-bad floor coils [Re: Philly]
Old Equipment Offline
1-SOB
1-SOB
Iowa
Clean and oil and then check level of switch. If possible adjust coil mounts so the movable core isn't wearing on the inside of the coil. Check for wear on insides of the coil.
Install new springs to kick the contacts off, problems disappear. Install new stationary contacts, especially carbons to add height. The sooner the contacts meet, the more spring you get for the release. But not too soon...
Your last option. You can also install a thin strip of non-magnetic metal (brass)between the cores. This last information comes from 1920's elevator books. Clean switch again.
Make sure the hinges for the movable contacts specs. include washers. One floor switch was sticking and a thin copper washer was added to the hinge to try to align the movable arm contact better (the magnetic forces tends to align the core just fine). The washer had a burr and was causing the sticking. Checked parts list, no washer, had washer removed. The floor coil operates correctly. Clean switch again.
#7078 - 05/17/13 02:20 PM Re: 1922 Otis SOB-bad floor coils [Re: Philly]
christycollett Offline
Green Pants, have a question for you. Older Otis wiring diagrams always start with a number. For instance 5-1S7***** what does the first number mean?
#7089 - 05/18/13 01:16 AM Re: 1922 Otis SOB-bad floor coils [Re: christycollett]
GreenPants Offline
GreenPants  Offline
no clue christy those are about 60 years before my time.
#7116 - 05/20/13 03:44 PM Re: 1922 Otis SOB-bad floor coils [Re: GreenPants]
1-SOB
1-SOB
Iowa
Sheet #GS27-4012, date June 3, 1955. GS27- note is -ARR for (2) 68594?? cam devices. Front & Rear ... Rectifier Arranged.
The GS27 in this case refers to a Otis mod of AC controller with a DC overlay for a new retiring cam motor and cam motor- ?automatic gate closer? Also changed was a direct AC brake for DC brake and a DC brake control panel was added. Original Sheet #4012, date July 19, 1920.
Sheet #GS4-3329F, date April 16, 1954 (condensed? wiring diagram). GS4- note- Added Potential Switch.
The expanded wiring diagram GS4-3329F starts #3329D, date March ?, 1917,then #3329E March 26, 1917, then #3329F May 10, 1917. Ends #GS4-3329F, date April 16, 1954. Assume #3329 is the original sheet #.
As far as your question about the later number designations, Christy Collett, I don't know but started at least by 8-CIF6834A, date start 1,24,1949. final? Jan 16, 1953.
#28262 - 11/21/19 08:18 PM Re: 1922 Otis SOB-bad floor coils [Re: Old Equipment]
PATRCIK Offline
PATRCIK  Offline
If you ever need parts for these old units check out Master Elevator Components they have a lot of parts for the 1940's and before.
www.masterelevator.net
Page 2 of 2 1 2
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.023s Queries: 16 (0.006s) Memory: 2.6922 MB (Peak: 2.8531 MB) Zlib disabled. Server Time: 2024-06-03 00:43:11 UTC
