0 registered members (),
spiders. |
Topics6,549
Posts37,013
Members8,546
Most Online117 Jan 16th, 2020
#36219 - 11/02/23 05:32 AM
Another TKE LEV problem
tthh
Denver
Need some guidance. There isn't a lot to be found on the net in the way of install and troubleshooting material on this elevator.
I'm a retired engineer and fully comfortable working on the LEV in this house that I bought earlier this year. Only two stories and the elevator worked fine until the other day.
Got an E8 error and after getting some materials from another LEV owner, I see that E8 is BP Error. I figure that BP is the bit position magnet plate. Elevator is at the first floor, which has no pit. I look around to see what I can see and the BP magnet plate has a lot of magnet shards on it and the magnet plate sensor on the cab is loose at the bottom and flapping around. I figure that's the issue, so I manually raise the cab with my monster 1/2" drill about 5 feet to get at the magnet plate to clean it off and line it up well with the cab mounted magnet plate sensor.
Well, when I raise up the cab, the cam plate on the right side falls off the rail !! This is where the final limit sensors on the right side of the cab are, which is a mirror image to the magnet sensor plate on the left side. I don't know how the cam plate is supposed to go back on the rail relative to the limit sensors. There is one bottom limit sensor and 2 top limit sensors. When the cab is parked properly at the bottom are all three of them tripped? Is the first one "slow down" and the top two "stop"? That's how I put it back to see if it would work. So then I manual reset the controller: hold the reset button, Run->Stop and back again and then let go of the reset button. The E8 is gone, but elevator is still not working. It did lower to the first floor, did not hit the floor and feels in the same height it always stops. But, now I get "d". All the other sensors are fine, so I figure the "d" is coming from the slack sensor on the very bottom which has to be manually reset. I manually raise the cab 4 feet and manually reset the slack sensor and then the controller and the elevator goes down to the first floor and stops and "d" again.
BTW, I re-torqued every bolt in the hoist way and on the exterior of the cab. Found about 10 that needed something, but nothing that could have resulted in a serious problem. This is now on my every two year list. It is no different from properly maintaining your car, which I do for 5 of them in the family.
So, I guess I have a few questions: (1) I'd love more compete service manuals -- this thing is built like a tank and as long as the electronics work... (2) How exactly is the bottom floor cam plate supposed to be placed relative to the final limit switches on the cab? (3) Why is the chain slack sensor triggering? The chains are fine and I see nothing that looks strange. The only thing I can think of is that all this manual up and down and short movements have messed somehow made it more finicky.
Also, I ordered a bunch of switches and a pendant box from Automation Direct to make my own pendant according to the pendant schematic I have. I also bought a couple of books from the Elevator World Bookstore since I'm going to be living here for the duration and I want to maintain this thing properly.
Thanks for reading!! Tom
#36232 - 11/03/23 04:42 AM
Re: Another TKE LEV problem
[Re: tthh]
tthh
Denver
Thank you for that valuable information.
This is the part that fell of the rail... [url=https://access2parts.com/lev-elevator-final-limit-cam/][/url]
#36265 - 11/11/23 01:34 AM
[Re: tthh]
tthh
Denver
Well, I have it back working!
Although, in the process the first floor call station display digit no longer lights. Not sure how that happened, maybe I did something or it was just a coincidence (I hope), but I can fix that later. I have emails out to access2parts and world-electronics to see about a spare and/or repair of the call station.
In the end there were many problems and I think there has probably been little to no maintenance performed over the years. The initial E8, BP Error was the actual problem that took the unit down. In the end, the magnet sensor for the first floor magnet went bad on the magnet sensor circuit board. I probed each magnet sensor with my multi-meter and ran the correct polarity magnet over each of them and BP1 did not react while BP2 and BP4 did. These sensors are hall sensors and similar to what's used on cars for wheel sensors and crankshaft and camshaft position sensors. In my experience on cars they do die occasionally. There are three magnet sensors on the circuit board and my house only has two floors, so I de-soldered the BP4 sensor since it is not used for for only two floors and put in in the place of BP1. They are surface mount components, but not the smallest, so doable without exotic soldering equipment. That was the fix that got it working. As to if something killed it or it was just a coincidence, I don't know, the magnet sensor board holder was loose and hitting the magnet sensor board.
Along the way, I found a dozen loose bolts here and there, a couple completely unscrewed, although none that would have caused a catastrophe. The first floor final limit switch cam plate was so loose it fell off the rail. The magnet sensor board was loose and hitting the magnet plate. There was magnet "dust" on both the first and second floor plates, although a lot on the first floor plate. I found a couple loose wires, although there could be more.
I made a pendant using the schematic so I could move the cab up and down easily. That is really a must have, especially given where the equipment controller is located.
Thanks for this forum and to everyone who had tidbits in the past and helped me now.
