0 registered members (), 17 guests, and 5 spiders.
June
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
8546 Registered Users
Topics6,556
Posts37,044
Members8,546
Most Online117
Jan 16th, 2020
#36553 - 01/10/24 11:44 PM Montgomery MG
Sf elevator Offline
Sf elevator  Offline
I have a Montgomery MG set installed a rebuilt hoist motor car first would run on inspection. Car no longer will run. I checked armature voltage and I’m only getting 35-45 vdc off generator motor is rated for 200v . When I read resistance on my fields I’m getting 15ohms shop said they should be 87ohms any ideas in which direction I should go from here? This is an old Montgomery where they use a shunt motor in damping circuit. I believe car is late 60 early 70s
#36555 - 01/11/24 12:21 AM Re: Montgomery MG [Re: Sf elevator]
john jay Offline
john jay  Offline
ohio
Something to check. Does The relay AR energize? It is a relay that is pulled in with amps, not volts. It is in the armature loop circuit. This is all way back memory so like I said, just something to look at.
#36556 - 01/11/24 12:46 AM Re: Montgomery MG [Re: Sf elevator]
john jay Offline
john jay  Offline
ohio
Another thought just occurred. I believe that the small shunt motor is what pulls AR relay in. The car will not go into high speed without AR. I think as the shunt spins it pulls in AR.
#36557 - 01/11/24 03:43 AM Re: Montgomery MG [Re: john jay]
Sf elevator Offline
Sf elevator  Offline
Thank you John jay. Tomorrow I’ll get back to you after having more time trying a few things . I believe your correct its something to do with this shunt motor not feeding circuit correctly .
Rotary Oildraulic
Old Otis badge.
Brakes,Coil,Rotor
KONE MX10 repair tool kit
Page Time: 0.023s Queries: 15 (0.005s) Memory: 2.6760 MB (Peak: 2.8259 MB) Zlib disabled. Server Time: 2024-06-10 00:07:53 UTC
