0 registered members (),
spiders. |
Topics6,555
Posts37,039
Members8,546
Most Online117 Jan 16th, 2020
#36666 - 01/26/24 07:06 PM
MX32 Kone Boost Brake Module
Flakes427
Good Afternoon,
I'll try not to make this too long, but received a call yesterday on a KONE Mono KCM. Of course, it's one of the critical cars in the Hospital, nonetheless, when I arrived, the car would not
1. Take a demand or hall call 2. Respond to Inspection or any Automatic call from the controller 3. E-Brake will pick but the car will not run in either direction.
Navigating through KONE's oh-so-friendly prints, it's leading me back to this Boost Brake Module for the Main Brake. Mind you, when given a direction via inspection, the car will not move. I don't have "Main Brake to CH1 or Main Brake to CH2" high. When I plug in XB1 (sorry if my terminals or name is incorrect, my head is spinning right now) into the E-Brake Module, "Main Brake to CH1 and Main Brake to CH2" go high or lite. It won't run under that condition, but can I assume that we have a bad boost brake board?
All other voltage checks, seem to check out. Even the output from the Main Brake Module of 480 and E-Brake 230. Very confusing, but what else could it be? Again, upon a direction, it will pick the E-brake and then fault out the drive w/o a direction (direction being movement). In addition, the ADON board is not faulting out, so again, I can't see any inputs shorted that may cause anything back to the ADON and/or CPU.
Any help is appreciated, thanks a bunch!
#36669 - 01/26/24 07:48 PM
Re: MX32 Kone Boost Brake Module
[Re: Flakes427]
Flakes427
