0 registered members (), 17 guests, and 0 spiders.
Posts36,656
#6993 - 05/13/13 10:02 AM Kone V3F16L 14A replacing with KDL16L 14A
balt Offline
balt  Offline
Hello,
I would like to know if anyone has changed these drives and if there is a set of parameters that has to changed or it fits by default,i have a monospace elevator 1000kg, 1 m/s.
Thank You.
#6994 - 05/13/13 01:38 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: balt]
Philly Offline
Philly  Offline
The parameter and software upgrades info comes with the drive when ordered through kone spares
#7025 - 05/14/13 02:33 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Philly]
Philly Offline
Philly  Offline
If only Kone didn't cheap out and use this drive in the first place with encoder control. Then again, they sold a hundred thousand of them.
#7029 - 05/14/13 05:35 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Philly]
Dmhughes Online content
Dmhughes  Online Content
Yorkshire UK
Hi,
Yes, I've fit loads of 16Ls but done my first KDL today, went well, all instructions come with it, there are some cable adapters a new brake & thermistor loom, you have to split the pods into separates ie 4 wires, encoder instead of tacho, & batt backup cable to connect into SEP, parameter address changes all in the paperwork that comes with it, just a bit more tricky than 16L.
I have the document should you need it.
Hope this helps
Dave
#9372 - 01/02/14 03:28 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Dmhughes]
neve_40 Offline
neve_40  Offline
Hi Dave
Should I install the kdl16. Posted by kone in the kit there are not instructions
could you send me the instructions for e-mail?
my email address is: neve_40@hotmail.com
thanks
greetings
Andrea
#9373 - 01/02/14 05:07 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: neve_40]
Yorkshire UK
Hi Andrea
Check email.
Dave
#9400 - 01/04/14 01:15 AM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Dmhughes]
Elev^te79 Offline
Elev^te79  Offline
Hi Dave ,
Could I look at those instructions as well ?
Robertridge79@gmail.com
#9592 - 01/20/14 06:05 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Elev^te79]
floki Offline
floki  Offline
Croatia
Hello Dave,i need instructions for changing V3f16L with new KDL...thanks
florijankosir@net.hr
#9593 - 01/20/14 11:53 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Philly]
koneisland Offline
koneisland  Offline
Don't get too excited about these new drives. Lots of reports about the new KDL's failing already.
#9602 - 01/22/14 09:37 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: koneisland]
Elev^te79 Offline
Elev^te79  Offline
Oh man ! Don't say that. What's happening with the KDL's now ?
#9603 - 01/22/14 11:12 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Elev^te79]
koneisland Offline
koneisland  Offline
Same old story and it is across the KDL range 16's 32's etc.and including KDM models
Keeps us employed I suppose
#9607 - 01/23/14 04:32 AM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: koneisland]
Elev^te79 Offline
Elev^te79  Offline
Secondary market is gonna make a fortune out of this.
#9613 - 01/24/14 02:28 AM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Elev^te79]
Kone D Offline
Kone D  Offline
My kdm and kdl's are doing fine, no problems keep your brake nut loose and rails oiled you will be fine.
#10066 - 03/12/14 04:29 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Kone D]
tony Offline
tony  Offline
I have had a number of these go at aprox. 5 years...do they had a timed mini bomb in them hahahah like the old eng service light for egr ..reset it and charge them 10 grand
#12297 - 10/12/14 08:47 AM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Dmhughes]
abukul Offline
abukul  Offline
Hi Dave
Please could i have those instructions as well ?
i got the unit without instrctions
many thanks
abukul
#16452 - 03/19/16 05:11 AM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: abukul]
samikaesh Offline
samikaesh  Offline
Hello guys ,i need instructions for changing V3f16L with new KDL...thanks
#16453 - 03/19/16 05:12 AM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: samikaesh]
samikaesh Offline
samikaesh  Offline
Casatrade@hotmail.com
#22794 - 01/19/18 05:35 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: balt]
davidneel Offline
davidneel  Offline
Hi dears any one know about the kone KDL16 s replacements procedure. Please help me . I have error 126 but I was tried to find .
#28648 - 01/26/20 08:09 PM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Dmhughes]
Sharafath Offline
Sharafath  Offline
Can anyone help me with the parameters pdf for replacing Kone V3f16l drive with KDL16L drive.?!
#28659 - 01/29/20 06:18 AM Re: Kone V3F16L 14A replacing with KDL16L 14A [Re: Sharafath]
Hope&Poke Offline
Hope&Poke  Offline
Texas
What's your email?
Page Time: 0.250s Queries: 15 (0.145s) Memory: 2.7990 MB (Peak: 3.0772 MB) Zlib disabled. Server Time: 2024-03-29 12:17:57 UTC
