spider. |
Topics6,521
Posts36,908
#17744 - 08/15/16 11:59 AM
Re: schindler 330A hall buttons
[Re: NOTIME]
Jcjmowrey
We've had to replace many of these boards as well but cannot find anyone like world that will repair them. We've also been told by schindler that they are "throw aways" when they go bad. Has anyone found a place that will repair?
#18094 - 09/22/16 01:21 PM
[Re: shlomo]
Shadowman
hello to all of you, does any one know if the drawings of schindler 3300 fit for schindler 5500 From what I've seen 5500 use a different controller. So one would assume it's different wiring for some parts. Other parts they would stick to the structure as the 3300. If you think about it, there's not much difference between a 3300 and a 5500 electrically. Only the inputs to the main controller would be different. The connections to the OKR would probably be the same. Good luck with your search.
#25212 - 11/20/18 11:39 AM
[Re: Vatorgator]
Maloudos
What is the software for programming hall call touch pcb new id on Schindler 6200?
