0 registered members (), 18 guests, and 0 spiders.
Posts36,820
#17059 - 05/15/16 12:02 PM Dover composite wild car
matt 24 Offline
matt 24  Offline
Hey guys, 4 car group,1 car runs non stop between bottom term.and next to top floor. Does not open doors or answer hall calls. It'll answer and cancel car calls and open doors but goes right back to problem. Didn't have much time to troubleshoot but checked for hung up relays,sel.switches,etc. any ideas?thanks
#17063 - 05/15/16 07:11 PM Re: Dover composite wild car [Re: matt 24]
Sounds like the Car has some type of demand to run and is not seeing the slow downs from the selector, but it see the slow down for car calls. The slow downs for Hall and Car calls originate from different points on the Selector, I would look there closely.
#17064 - 05/15/16 09:26 PM Re: Dover composite wild car [Re: john jay]
christycollett Offline
Might be the card for the lev optals. if it's bad car will run from top to bottom forever.
#17065 - 05/15/16 09:41 PM Re: Dover composite wild car [Re: christycollett]
matt 24 Offline
matt 24  Offline
Thanks guys,I'll try again tomorrow
#17073 - 05/16/16 08:39 PM Re: Dover composite wild car [Re: matt 24]
matt 24 Offline
matt 24  Offline
Ended up being load weighed contact holding up BY. Understand why it wouldn't answer hall calls not sure why it was running nonstop? Thanks for the help guys.
#17075 - 05/17/16 02:04 AM Re: Dover composite wild car [Re: matt 24]
vatormx Offline
vatormx  Offline
TX
Might have two things going on. Check you back contact on SE #3 sometimes will get a burr on it and fire OT which will run top to bottom.
#22773 - 01/17/18 07:10 PM Re: Dover composite wild car [Re: matt 24]
Tamperprufe Offline
Tamperprufe  Offline
not able to find posting with my particular issue so trying here...
Have 2 car bank Dover Composite with 2 issues, only really concerned with the one issue but describing both as they are dispatching issues and maybe related.
This is the smaller composite controllers with the plastic covered hall/car call relays mounted on the back side of controller and not IBM style front swing panel ones
Issue #1- Both elevs intermittently will answer same hall call...haven't spent much time on that one so not sure about any pattern, rhyme or reason.
Issue #2- If car #4 is not on 1st Fl.landing and car #5 IS AT 1st. Fl. landing and 1st Floor hall call is sealed car #5 which is sitting there idle will not respond to hall call, doors never open, other car #4 will also
not respond so 1st floor hall call stays sealed basically shutting down 1st floor operation.
- Car #5 has to be IDLE at 1st Floor landing for this to happen, if car is at any other floor it will come down and answer 1st Fl hall call
- I assume car #4 (dispatch car) recognizes that car #5 has been assigned to answer 1st Floor hall call so that is why it (car #4) stays put
- I have confirmed that both controller 1st Fl relays are pulled in.
- If I give car #5 a car call to leave 1st floor then other car #4 will come down to answer 1st floor hall call
- I have seen this condition and both generators go to sleep with 1st Fl hall call still sealed.
- I can use "CS" or "CR" relays to open doors and answer/cancel hall call
I suspect it's related to car #5 selector floor bar issues or relay back contacts in car #5 1st.Fl hall call circuit
any help would sure be appreciated, Thxs
Page Time: 0.081s Queries: 17 (0.014s) Memory: 2.6995 MB (Peak: 2.8777 MB) Zlib disabled. Server Time: 2024-04-26 06:11:29 UTC
