1 registered members (Boomz808), 14 guests, and 0 spiders.
Posts36,788
#17386 - 06/28/16 07:48 PM Kone resolve 20 1301 fault
NewMechanic Offline
NewMechanic  Offline
Hey,
Just looking for some info on the COP card LCEOB24. I am getting a 1301 fault and tried a 5.7.2. Followed by 5.7.1. It seems to see the board however keeps shutting down on fault 1301. The only other faults I'm getting is the occasional 101 and 169. Checked the wiring and replaced the cartop battery. Also tried swapping with another board (fairly certain it was good..)
Anything else you guys recommend trying before I order a new COP board?
#17619 - 07/26/16 03:31 AM Re: Kone resolve 20 1301 fault [Re: NewMechanic]
BRG Offline
BRG  Offline
Is the LON connected properly? XS1 is in and XS2 is out. Can you see the terminating resistor with a meter?
#17620 - 07/26/16 04:37 AM Re: Kone resolve 20 1301 fault [Re: BRG]
COB boards are known for blowing on power off and on. The newest version is supposed to fix the Power off and on problem. Seen the new ones blow also. That is a board to keep in stock for sure if you want to keep cars in service.
#29881 - 09/07/20 09:08 AM Re: Kone resolve 20 1301 fault [Re: NewMechanic]
my luft Offline
my luft  Offline
Good evening. i have a similar problem. thinking of replacing the board but i do not now it the new one has to be registered on the network using the Kone hand tool.
can you advise us?
#29967 - 09/26/20 10:19 AM Re: Kone resolve 20 1301 fault [Re: NewMechanic]
KONE89 Offline
KONE89  Offline
Do not do a force download 5-7-2 you will cause more problems. You need to check if you have the right G01 or G11 number on the COB24 board that your replacing. Then you need to do a LON download 5-7-1. Also is the lift staying on fire service? what are the car buttons doing? how many COPs do you have? If you have 2 COPs it could be either COB24 board or even a CEB extension board.
#30082 - 10/23/20 06:55 PM Re: Kone resolve 20 1301 fault [Re: NewMechanic]
James16 Offline
James16  Offline
1301 & 0169. Same issues. Replaced MUL and CCB same issue. What's next?
#30093 - 10/26/20 11:09 PM Re: Kone resolve 20 1301 fault [Re: James16]
BRG Offline
BRG  Offline
The 0169 is saying the battery is low. Go to 5-14 set it to 22 and cycle power, if you change the ccbn you'll need to do a download, 5-7-1
Page Time: 0.098s Queries: 16 (0.050s) Memory: 2.6935 MB (Peak: 2.8717 MB) Zlib disabled. Server Time: 2024-04-19 18:41:05 UTC
