0 registered members (), 17 guests, and 0 spiders.
Topics6,487
Posts36,753
#21617 - 09/15/17 11:27 AM KONE ELEVATOR(LIFT) POWER BACKUP
ItuBaba Offline
ItuBaba  Offline
Hello Gurus,
we need to support a Kone monospace with a power backup (UPS or inverter) to enable it work for 10 minutes without power.
i need as much advice and tips and what to avoid. The specs of the elevator are:
Type: Kone Monospace
Equipment Number: 42323221
Spec: W08/10-19
Controller Cabinet Type: LCE-KDL16
Thank you,
#21619 - 09/15/17 07:04 PM Re: KONE ELEVATOR(LIFT) POWER BACKUP [Re: ItuBaba]
You need a backup Generator. Call a licensed electrician and have him look at the controller. The Voltage,Amperage and other power information is readily visible on a plate in the control panel. He will then be able to price out the wattage a backup Generator will need to run the unit.
#21638 - 09/17/17 09:19 PM Re: KONE ELEVATOR(LIFT) POWER BACKUP [Re: john jay]
ItuBaba Offline
ItuBaba  Offline
Thank you.
Will the controller be the large cabinet unit. Where will the plate on the control panel be so we can read off.
#21676 - 09/21/17 07:08 AM Re: KONE ELEVATOR(LIFT) POWER BACKUP [Re: ItuBaba]
heisenberg Offline
heisenberg  Offline
Control cabinet is on the top floor door panel.
#21747 - 09/28/17 01:01 PM Re: KONE ELEVATOR(LIFT) POWER BACKUP [Re: heisenberg]
ItuBaba Offline
ItuBaba  Offline
Thank you,
Lorenzo
Page Time: 0.125s Queries: 16 (0.062s) Memory: 2.6761 MB (Peak: 2.8347 MB) Zlib disabled. Server Time: 2024-04-16 14:09:44 UTC
