1 registered members (Elevatorchum), 11 guests, and 0 spiders.
Topics6,487
Posts36,753
#21626 - 09/15/17 11:14 PM KCK831 Error 0169
Elevate66 Offline
93 Cobra Mustang
Elevate66  Offline
93 Cobra Mustang
Utah, United States
Hello to all my hard working fellow technicians.
KCM831 error 0169 Please help? I'm assuming back-up batteries? Unable to locate the UPS. Look forward to someones response.
Respectfully,
#21627 - 09/15/17 11:16 PM Re: KCK831 Error 0169 [Re: Elevate66]
Elevate66 Offline
93 Cobra Mustang
Elevate66  Offline
93 Cobra Mustang
Utah, United States
It runs fine from inside the car but will not respond to hall calls.
#21628 - 09/15/17 11:53 PM Re: KCK831 Error 0169 [Re: Elevate66]
0169- The main line supply has been off to long or battery itself is broken
The automatic battery test has detected low battery
#21629 - 09/16/17 12:17 AM Re: KCK831 Error 0169 [Re: Elevate66]
beaupeep Offline
beaupeep  Offline
ontario
Replace the battery and start a 3 year cycle. Battery is in the cartop unit
#21630 - 09/16/17 01:35 AM Re: KCK831 Error 0169 [Re: beaupeep]
You can set menu 5 parameter 14 to 22 to disable the battery supervision for 22 hours until you get a new battery.
#21634 - 09/17/17 06:05 AM Re: KCK831 Error 0169 [Re: Indirtwetrust]
Yeah, and when you open that car top box and ask yourself, " How the hell do I get that battery out of there?", simply loosen the two top phillips screws on the side ends of the box that support the battery and it folds down for easy access.
#21644 - 09/18/17 06:53 PM Re: KCK831 Error 0169 [Re: elmcannic]
Elevate66 Offline
93 Cobra Mustang
Elevate66  Offline
93 Cobra Mustang
Utah, United States
Yep, that was definitely a problem. The battery is bulging and actually charging @ 14VDC. We'll get it replaced and turn down the pot and hopefully that's it. Thanks for all your help.
Respectfully,
#21682 - 09/21/17 09:08 PM Re: KCK831 Error 0169 [Re: Elevate66]
Upndwn Offline
Elevator Guy
Upndwn  Offline
Elevator Guy
The side of the car top box with the battery
Slides out. Loosen the battery holder screws
Then 2 on each side of the box at the top
And that side of the box will fold down.
Unless someone put a stop switch or something else
In the way hope this helps
Page Time: 0.039s Queries: 16 (0.005s) Memory: 2.7001 MB (Peak: 2.8850 MB) Zlib disabled. Server Time: 2024-04-16 13:22:36 UTC
