0 registered members (), 11 guests, and 0 spiders.
Posts36,656
#22005 - 10/25/17 08:23 PM Kone lift with kdl 32 drive
wael jouni Offline
wael jouni  Offline
Kindly i have kone elevator with kdl32 drive giving fault 0007 ,(pin 30 stuck) lift stop at level and keep doors open , after rest it work and this fault comes 2 to 3 times per a day and some times work wor a month no fault , i change the pin 30 many times , i changed top of car board +ADO+ LCECPU to test and still have same problem , any one pass in this before ?
#22155 - 11/09/17 03:45 AM Re: Kone lift with kdl 32 drive [Re: wael jouni]
Lifty Offline
Lifty  Offline
I have had this one before - Check the distance between 61U and 61N inductors and magnet on the floor that you are having the issue. Alternatively, replace 61U and 61N inductors[pins] one of them is faulty!
#22170 - 11/12/17 06:34 PM Re: Kone lift with kdl 32 drive [Re: wael jouni]
Azhar hussain Offline
i am facing issue in kone elevator that lift start and goes downward in rated speed after 5 sec. and lift stop at next floor on maintenance speed error code occur 0152. kindly help me.
#22200 - 11/17/17 01:24 AM Re: Kone lift with kdl 32 drive [Re: Azhar hussain]
Lifty Offline
Lifty  Offline
Check 77U, 77N, 77S inductors.
Page Time: 0.032s Queries: 16 (0.010s) Memory: 2.6684 MB (Peak: 2.8191 MB) Zlib disabled. Server Time: 2024-03-29 09:58:38 UTC
