0 registered members (), 8 guests, and 1 spider.
Topics6,492
Posts36,772
#22454 - 12/13/17 06:10 PM Otis 1928 geared SOB controller
Tom Daake Offline
TommyBoy
Tom Daake  Offline
TommyBoy
Mo
I need help with this one. I have recabled the system and get power but the car won't move when called. There is power to all relay switches, so does anyone have any suggestions of what i should try? I can manually push in the magnet contacts and the car moves just fine, but it won't move when any call button is pushed. I have tried replacing relays but no fix yet...any help would be appreciated.
#22455 - 12/13/17 06:34 PM Re: Otis 1928 geared SOB controller [Re: Tom Daake]
Do you have a print? I have a 1FSOB C-6810. PM me an email will scan and send. Does it run from car buttons and not hall? Does anything on controller pick up at all? If not you need the print.
#22456 - 12/13/17 06:36 PM Re: Otis 1928 geared SOB controller [Re: Tom Daake]
Also have a 1-SOB A-7383
#22458 - 12/13/17 11:22 PM Re: Otis 1928 geared SOB controller [Re: Tom Daake]
northstar Offline
northstar  Offline
How much power have you at the Relais? Please take a Voltmeter
#22757 - 01/16/18 12:19 PM Re: Otis 1928 geared SOB controller [Re: Tom Daake]
Maxelev Offline
Maxelev  Offline
Did you try calling unitec with the machine number? They can usually get them from you.
#22758 - 01/16/18 01:16 PM Re: Otis 1928 geared SOB controller [Re: Tom Daake]
When you recabled did you possibly trip a switch in the safety circuit? Check crosshead SOS switch, Governor Switch, Pit switch, and Limit switches, Some of them had a switch on Pit Door if it was a walk in pit. Not much else there except doors, gates, &fuses.
Page Time: 0.035s Queries: 16 (0.009s) Memory: 2.6842 MB (Peak: 2.8529 MB) Zlib disabled. Server Time: 2024-04-18 09:43:23 UTC
