0 registered members (), 10 guests, and 0 spiders.
Topics6,499
Posts36,809
#23186 - 02/22/18 07:47 PM Kone KCM831 E0108 error
kenelev Offline
kenelev  Offline
Hi Guys:
Got error code 0108
Kone KCM831 with V3F16L drive
When try to run down on inspection, elevator drift up and shutdown.
Any idea can help.
Thanks,
Ken
#23187 - 02/22/18 08:39 PM Re: Kone KCM831 E0108 error [Re: kenelev]
the fault code says it is a Tach error, or a load balance error.
#23190 - 02/23/18 12:15 AM Re: Kone KCM831 E0108 error [Re: kenelev]
Thomass Offline
Thomass  Offline
Strip and clean out the Tacho then double check load weigher is calibrated (menu 5 submenu 1 should read close to 0 empty car mid shaft. Number displayed is % of load).
#23193 - 02/23/18 03:44 AM Re: Kone KCM831 E0108 error [Re: kenelev]
kenelev Offline
kenelev  Offline
Thanks guys,
Will check out the tach tomorrow.
As for the load weighter, I cannot run car down because every time try to run down. The elevator drift up and shutdown.
Is there any way to run the car by disable the load weighter?
Or what is the % of the load shoulf be when can @ top ?
Thanks,
Ken
#23197 - 02/23/18 12:50 PM Re: Kone KCM831 E0108 error [Re: kenelev]
I think u can set 5-1 to 50% for construction if i remember
#23210 - 02/23/18 09:24 PM Re: Kone KCM831 E0108 error [Re: kenelev]
kenelev Offline
kenelev  Offline
Thank you guys, is anybody have a copy of setup guide?
Thanks,
Ken
#30241 - 11/30/20 12:02 PM Re: Kone KCM831 E0108 error [Re: kenelev]
olugbemileke Offline
Elevatrics
Elevatrics
Any Update @Kenelev, I have a similar problem.
By Tacho, do You mean the Encoder?
#31646 - 08/31/21 10:53 PM Re: Kone KCM831 E0108 error [Re: olugbemileke]
Adamabm Offline
Adamabm  Offline
Im having the same issue! Were you ever able to figure it out?
#31652 - 09/01/21 01:31 PM Re: Kone KCM831 E0108 error [Re: kenelev]
Jadam Offline
Jadam  Offline
Clean the encoder, adjust the load weight 50% and 0% top and button shaft.
After that a new shaft setup is a good idear smile
#34279 - 11/28/22 02:25 AM Re: Kone KCM831 E0108 error [Re: kenelev]
irfan Offline
Happy Birthday irfan  Offline
Karachi
Look like you have broken DCBL board.
Troubleshoot to KONE elevator is fun.
Page Time: 0.077s Queries: 16 (0.030s) Memory: 2.7166 MB (Peak: 2.9178 MB) Zlib disabled. Server Time: 2024-04-24 17:41:58 UTC
