0 registered members (), 7 guests, and 0 spiders.
Topics6,489
Posts36,756
#24549 - 08/21/18 05:36 PM Thyssenkrupp- adjust door-open time
MBF Offline
MBF  Offline
Hi
I have a problem about adjusting door-open time. My problem is that when the car is in landing, the door closes at speed so that it hits the passengers. Therefor I have changed this parameter by diagnostic units I and (VI) (WINDIAG software) but this change doesn't execute or apply on the door and it's still like before without any change.
Can anybody help me with my problem.
#24550 - 08/21/18 07:22 PM Re: Thyssenkrupp- adjust door-open time [Re: MBF]
Tamperprufe Offline
Tamperprufe  Offline
if it's just a speed and or timer parameter adjustment then it's an easy fix, maybe someone here has the info to help you however on this forum most people use IMS not WINDIAG.
#24567 - 08/22/18 07:03 PM Re: Thyssenkrupp- adjust door-open time [Re: MBF]
Hits passengers? Better take the unit out of service ASAP until you get it fixed.
First; when blocked, does the detector edge work properly?
It sounds like your door closing speeds are culprit not door open time.
If your diagnostic has instructions, look at door adjustments for speed control. Or, the door card may be bad not allowing for values changed.
Also be sure the car door is mechanically sound. Loose bearing connection points can cause the doors
to not respond to control inputs as it should.
#24601 - 08/26/18 04:05 PM Re: Thyssenkrupp- adjust door-open time [Re: Tamperprufe]
MBF Offline
MBF  Offline
thank you
is IMS a software? and can I change this parameter by it?
#24602 - 08/26/18 04:19 PM Re: Thyssenkrupp- adjust door-open time [Re: MBF]
MBF Offline
MBF  Offline
thank you
door closing speed is similar to other elevators.but a way, there are tow door in the elevator and both of them have the problem. So there is not mechanical problem.
where is detector edge?
#24603 - 08/26/18 06:07 PM Re: Thyssenkrupp- adjust door-open time [Re: MBF]
MBF Offline
MBF  Offline
it is important you know that the electronic card is MC3
#24604 - 08/26/18 08:53 PM Re: Thyssenkrupp- adjust door-open time [Re: MBF]
jkh  Offline
MBF,
I’ve never used, nor am I familiar with the software you are using. There are multiple door time parameters that control multiple door functions. How do you know you are even trying to change the correct parameters? Did the software come with a manual?
What is your profession?
#24627 - 08/28/18 11:02 PM Re: Thyssenkrupp- adjust door-open time [Re: MBF]
Tamperprufe Offline
Tamperprufe  Offline
yes IMS(USA) is a diagnostic tool just like the WINDIAG(European) tool you are using however they are not compatible or interchangeable
#24639 - 08/30/18 04:27 PM Re: Thyssenkrupp- adjust door-open time [Re: MBF]
Huskervator Offline
Huskervator  Offline
Parameter D24 is car call dwell time. D25 is hall call dwell time.
Page Time: 0.036s Queries: 16 (0.012s) Memory: 2.7096 MB (Peak: 2.9025 MB) Zlib disabled. Server Time: 2024-04-16 21:36:31 UTC
