0 registered members (), 15 guests, and 1 spider.
Posts36,789
#24950 - 10/10/18 01:36 PM DMC piston check valves
Philelevman Offline
Philelevman  Offline
St Louis Mo
I have a telescopic jack on a Thyssen DMC and the pistons will not resync. Ordered new piston check valves but I've yet to perform this task. Any helpful suggestions?
Philelevman
#24967 - 10/11/18 08:39 PM Re: DMC piston check valves [Re: Philelevman]
Jcjmowrey Offline
Jcjmowrey  Offline
Order seal kits as well. That’s more than likely your problem.
#25005 - 10/16/18 08:28 PM Re: DMC piston check valves [Re: Jcjmowrey]
Philelevman Offline
Philelevman  Offline
St Louis Mo
Thanks. We did. The pistons are carrying oil so not sure that is keeping us from synchronizing with zero pressure but I figured if I'm taking it apart I'm not gonna do it twice lol
Philelevman
#25028 - 10/19/18 05:22 AM Re: DMC piston check valves [Re: Philelevman]
Daniel freeland Offline
order the internal seals for the bottom of the pistons. 3 stage tele has 2 internal seals and the 2 stage has 1 internal. Per jack
#25029 - 10/19/18 10:37 PM Re: DMC piston check valves [Re: Philelevman]
Make sure you use Gorman packing.
Page Time: 0.052s Queries: 16 (0.008s) Memory: 2.6763 MB (Peak: 2.8351 MB) Zlib disabled. Server Time: 2024-04-20 06:16:25 UTC
