1 registered members (gohana256), 13 guests, and 0 spiders.
Posts36,654
#25350 - 12/05/18 06:55 PM Otis GEN 2 EFO - P Problem
sampler Offline
sampler  Offline
Hello. I have a problem on GEN 2. Although changing EFO - P paramater as 2, the elevator travels 1st floor. Could you help me. Thanks.
#25355 - 12/05/18 11:29 PM Re: Otis GEN 2 EFO - P Problem [Re: sampler]
workingclass Offline
Do you have a floor below 1st? Basement?
#25357 - 12/06/18 02:06 AM Re: Otis GEN 2 EFO - P Problem [Re: sampler]
I think you need to change EFO-CK too.
#25385 - 12/10/18 08:44 AM Re: Otis GEN 2 EFO - P Problem [Re: workingclass]
sampler Offline
sampler  Offline
We have basement. Floor names are -1,0,1,2,3. thanks
#25386 - 12/10/18 08:46 AM Re: Otis GEN 2 EFO - P Problem [Re: Indirtwetrust]
sampler Offline
sampler  Offline
There is not EFO-CK parameter. Could be a diffrent name of it. Thanks.
#25387 - 12/10/18 11:12 AM Re: Otis GEN 2 EFO - P Problem [Re: sampler]
Where do you want it to recall to
#25388 - 12/10/18 02:47 PM Re: Otis GEN 2 EFO - P Problem [Re: sampler]
sampler Offline
sampler  Offline
we want to recall to "0" floor. Also the controller is GCS 222.
Best regards.
#25426 - 12/16/18 11:39 PM Re: Otis GEN 2 EFO - P Problem [Re: sampler]
TNHapa84 Offline
TNHapa84  Offline
M 1-3-1--6 on tool which is emergency, then go on 26 times to EFO-P landing 1-64 is front doors
landing 101-164 is rear doors
landings 201-264 is both doors
also Next is EFO-CK Change to match EPO-P
after changing Do a reset M 1-5-1
should be good
#25427 - 12/17/18 06:53 PM Re: Otis GEN 2 EFO - P Problem [Re: sampler]
sampler Offline
sampler  Offline
I didnt find the EFO CK
I will check again. Thank you. Best ragards.
#25430 - 12/18/18 02:51 AM Re: Otis GEN 2 EFO - P Problem [Re: sampler]
TNHapa84 Offline
TNHapa84  Offline
It should be right after EFO-P.... do you have a blue tool that is unlocked?
#25431 - 12/18/18 02:55 AM Re: Otis GEN 2 EFO - P Problem [Re: sampler]
TNHapa84 Offline
TNHapa84  Offline
Have you changed EFO-P to 1 then blue enter. Then clear ram m-1-5-1. Then tried it?
#25450 - 12/20/18 05:17 PM Re: Otis GEN 2 EFO - P Problem [Re: TNHapa84]
sampler Offline
sampler  Offline
thank you very much. I will make your advice. the elevator is in another city and far away. it will go 2 weeks later. best ragards
Page Time: 0.063s Queries: 15 (0.025s) Memory: 2.7324 MB (Peak: 2.9506 MB) Zlib disabled. Server Time: 2024-03-29 01:34:39 UTC
