Topics6,498
Posts36,806
#26300 - 03/25/19 05:55 PM
330a
Jcjmowrey
Have a 330a with varidor operator giving a 94 error with extra info 0000 0010. Gate switch isn’t hanging up, we’ve changed cio and 360 with new. Swapped crip and varidor unit with identical elev in the same building. Checked belt tension and all wiring. Problem keeps shutting unit down about once or twice a week. According to error description I would think the problem would either be caused by gate switch hanging up or circuit staying high, or the varidor thinking it’s on the virtual open limit for some reason when the doors are closed. Anyone have any suggestions
#26312 - 03/27/19 02:05 AM
Re: 330a
[Re: Jcjmowrey]
Jcjmowrey
There is only 1 switch at dcl. I’ve got other 330a’s with the tdcb board that have 4 switches. This has the varidor inverter box behind COP. I have no experience with these but I’m thinking it creates virtual limits when it does a learn run. And what I’m calling dcl, might just be a secondary gate switch?
#26319 - 03/28/19 01:13 AM
Re: 330a
[Re: Jcjmowrey]
Jcjmowrey
Doors are free but will try changing switch
#26327 - 03/28/19 04:25 PM
Re: 330a
[Re: Jcjmowrey]
Jcjmowrey
That was one of the first things we did
#26357 - 03/31/19 02:22 PM
Re: 330a
[Re: Jcjmowrey]
Jcjmowrey
I understand 94 is a catch all for door faults, but with extra info being 0000 0010, I would think it has to do with gate switch or open limit specifically. Huskervator, are you saying software version may be throwing me off into left field because the actual issue is a mismatch with the extra info? And I haven’t paid attention to software version yet so I can’t say what it is yet.
#26662 - 04/20/19 01:02 PM
Re: 330a
[Re: Jcjmowrey]
Jcjmowrey
Had switch replace, ran for a few days then same problem. Version is 3.59 so huskervator , it probably needs software update correct?
