0 registered members (), 21 guests, and 2 spiders.
#26349 - 03/31/19 01:12 AM Dover Composite Overshooting Floors
wltr00 Online content
wltr00  Online Content
I have a Composite that is overshooting floors. Any suggestions on where to start?
#26350 - 03/31/19 01:58 AM Re: Dover Composite Overshooting Floors [Re: wltr00]
How much is it overshooting? both directions?? Stopping sequence ISL, LU or LD, 2LR RTT(not dropping) RE 14 & 15 contactors working (core pin not loose)
#26355 - 03/31/19 02:04 PM Re: Dover Composite Overshooting Floors [Re: wltr00]
Jcjmowrey Offline
Jcjmowrey  Offline
I recently had a 7 stop overshooting floors in both directions at all stops but top ,bottom , and 4th floor. I checked everything having to do with compounding and I thought I had checked everything having to do with selector. I checked pie plates, cable, bearings, sensors, etc and everything seemed fine. I finally realized the set screws at the end of the shaft with the pie plates were loose on the opposite end from the drum and the whole shaft had shifted maybe 3/16’s of an inch. Why it didn’t effect floors 1,4,and 6 was kind of misleading
#26356 - 03/31/19 02:04 PM Re: Dover Composite Overshooting Floors [Re: wltr00]
Jcjmowrey Offline
Jcjmowrey  Offline
1,4and7
#26366 - 03/31/19 08:07 PM Re: Dover Composite Overshooting Floors [Re: wltr00]
TC7  Offline
If overshooting both directions, is CLC pulling in at the end of run?
#26447 - 04/04/19 02:28 PM Re: Dover Composite Overshooting Floors [Re: wltr00]
Seco2000 Offline
DesertVatorMan
Seco2000  Offline
DesertVatorMan
S.CA., USA
Just a note about Stuthers-Dunn relays ....14 15...armature pins are known to break. Relay appears to work but contacts do not make or break.
#26545 - 04/13/19 12:14 AM Re: Dover Composite Overshooting Floors [Re: wltr00]
Whadafack Offline
Whadafack  Offline
Slack in your selector cable
#26549 - 04/13/19 08:16 PM Re: Dover Composite Overshooting Floors [Re: wltr00]
Philly Offline
Philly  Offline
Yep. Tighten it up on the cartop
#26615 - 04/17/19 12:20 PM Re: Dover Composite Overshooting Floors [Re: wltr00]
boomer Offline
boomer  Offline
Also make sure you have plenty of spring tension on the selector cable under the car. 14 and 15 are crucial!
Page Time: 0.085s Queries: 17 (0.015s) Memory: 2.7112 MB (Peak: 2.9043 MB) Zlib disabled. Server Time: 2024-04-26 00:23:57 UTC
