0 registered members (), 24 guests, and 0 spiders.
#26596 - 04/16/19 03:30 PM T3 CD Issue
wltr00 Offline
wltr00  Offline
I'm having a close door issue with a T3.
The attached photo shows my CD output is active, but I am not measuring 120VAC on P11 of the CD output IO. I have changed the PMI module and still no output. I have 120VAC on the P10 input to the CD IO. My doors are open and I cannot get them to close because I cannot activate the CD relay. If I jump 120VAC to to CD the relay energizes and the doors close.
Not sure what is going on here. Appreciate any help.
#26602 - 04/16/19 10:37 PM Re: T3 CD Issue [Re: wltr00]
So you replaced PMI module 38 on PMI card #1? Did you check the Pico fuse for M38? That print doesn’t match your I/O map. Module 38 is P5-3 common, P5-19 output. Always go by the I/O map.
#26606 - 04/16/19 11:15 PM Re: T3 CD Issue [Re: wltr00]
boomer Offline
boomer  Offline
Make sure you used the correct module as well there are several different ones
#26633 - 04/18/19 12:21 AM Re: T3 CD Issue [Re: wltr00]
Do you have power at OD 21/21? If not, pico fuse or output module. If yes, open coil on CD, or mechanically stuck?
Page Time: 0.067s Queries: 16 (0.017s) Memory: 2.6718 MB (Peak: 2.8276 MB) Zlib disabled. Server Time: 2024-04-25 19:37:18 UTC
