0 registered members (), 7 guests, and 0 spiders.
Topics6,492
Posts36,772
#28371 - 12/03/19 04:14 PM Kone New Drive Hoistway learn
Hannibal Offline
Hannibal  Offline
Hi, i have the problem i change the drive to a new KDL16 but when i try do the learn of the hoistway nothing works.
i follow the instruccion of the paper that kone send but nothing works. Someone have this problem ?
#28376 - 12/03/19 08:40 PM Re: Kone New Drive Hoistway learn [Re: Hannibal]
Hannibal Offline
Hannibal  Offline
On menu 5-2-1 always say no floor.
#28378 - 12/04/19 12:32 AM Re: Kone New Drive Hoistway learn [Re: Hannibal]
LA Tech Offline
LA Tech  Offline
61U, 30, 77N, 77S on. 61N 77U off. I assume you have a running car on inspection. What mode is 4-1 when you take car off insp. while trying to do shaft setup? Close end on door operator made up?
#30216 - 11/25/20 02:07 AM Re: Kone New Drive Hoistway learn [Re: Hannibal]
Jubril Offline
Jubril  Offline
If any engineer could please assist me on how to reprogram the floor numbering from the LON board...since then replacement of the board, the "G floor" is showing "1" while "3rd floor" displaying "4th" on KONE MONOSPACE
#30221 - 11/25/20 07:04 PM Re: Kone New Drive Hoistway learn [Re: Hannibal]
Jadam Offline
Jadam  Offline
Set all the drive parameters
Checking the load weighing device
Place the elevator under the bottom floor before making a shaft setup in rdf, then menu 5-2-1.. put the lift in normal mode and the elevator starts the setup driving up..
#30222 - 11/25/20 07:06 PM Re: Kone New Drive Hoistway learn [Re: Jubril]
Jadam Offline
Jadam  Offline
Jubril... check menu 3-1 and menu 3-2
#30229 - 11/27/20 06:03 PM Re: Kone New Drive Hoistway learn [Re: Jadam]
Jubril Offline
Jubril  Offline
@jadem, thank you very much. You're appreciated.
Page Time: 0.038s Queries: 16 (0.012s) Memory: 2.6922 MB (Peak: 2.8672 MB) Zlib disabled. Server Time: 2024-04-18 02:56:19 UTC
