Posts36,789
#28386 - 12/04/19 05:15 PM
Re: Dmc fast program
[Re: Tech9]
Tech9
I hooked up my fast tool to car station ..I had no response from device I unplugged all connections to CLC besides the top connector and still had no response from device. I replaced CLC and selector board and still have no response from device. I did power off and reboot each time I unplugged connectors. I hooked up service tool to nearby dmc to make sure service tool is good. Car runs on inspection. What is the TC ? Traveling cable ? This all happened after piston seals where replaced
#28387 - 12/04/19 07:09 PM
[Re: Tech9]
Tech9
85. ohms across PSC and NSC. Power supply is good
#28389 - 12/04/19 09:42 PM
[Re: Tech9]
Tech9
Yes I have plugged in all ports. Toc machine room and Car panel . I read between psc and nsc. Watchdog led is steady red on clc. Selector board and door board lights are on also. Does anyone have power supply part number
#28391 - 12/04/19 09:46 PM
[Re: Tech9]
Tech9
Its front door openings only. I. do have spares. But they are shielded. Not sure if have spares like that in tc Should I disconnect Psc and nsc in machine room and car station panel and check continuity. ?
#28392 - 12/04/19 10:51 PM
[Re: Tech9]
Indirtwetrust
#28400 - 12/05/19 02:45 PM
[Re: Tech9]
Tech9
I got communication after hooking all original boards and software back up. Now I’m trying to do learn run and getting a 10 fault on selector. Pulse count indicates out of door zone Possible my sensor board behind selector board is bad?
#28404 - 12/05/19 05:05 PM
[Re: Tech9]
Jluff
