0 registered members (), 7 guests, and 0 spiders.
Posts36,790
#28614 - 01/23/20 12:07 PM Dmc fault 019-001
Getting a power loss detected , but no power loss to system fault . The AC supply to CLC dropped , but p5 supply did not . I noticed when the fault happened I lost my light on reverse phase relay . So I pulled it and the car still worked. It was jumped out from previous company . Some one gets stuck once a day with this error. Do you think my car station panel power supply is bad ? Or is this a wiring issue ? Where does my AC power come into CLC ?
#28615 - 01/23/20 12:36 PM Re: Dmc fault 019-001 [Re: Jluff]
I’m thinking building power or my disconnect forks are the problem because I lose light on phase monitor relay. What do you guys think ?
#28620 - 01/23/20 10:39 PM Re: Dmc fault 019-001 [Re: Jluff]
That makes sense. On the other hand I have seen those orange VMs get pretty erratic when they fail. Could also be the toggle switch in the COP. I believe the AC comes in on LCC11 pins 13 & 15.
#28621 - 01/24/20 12:28 PM Re: Dmc fault 019-001 [Re: Jluff]
Thanks dirt. electricians from the building said the line from breaker was a mess and they repaired it. Got the car running now. We will see if happens again
#28644 - 01/26/20 06:56 PM Re: Dmc fault 019-001 [Re: Jluff]
Philly Offline
Philly  Offline
Ive come across about 5 of those RPRs bad, causing issues. All but one was useless, meaning that it was already upgraded to soft starter, but [censored] didn't remove it from circuit.
Page Time: 0.039s Queries: 16 (0.010s) Memory: 2.6766 MB (Peak: 2.8358 MB) Zlib disabled. Server Time: 2024-04-20 08:27:43 UTC
