1 registered members (Gurunath), 15 guests, and 0 spiders.
Posts36,783
#28869 - 03/12/20 10:32 PM Thyssen TCM Circa 2001 Drawbridge Evolution
KoneLiftEngineer Offline
Hello,
I have a lift, where I can run on test but on switching to normal I am stuck on Adjusting Run but I get no movement are there any possible causes for this, I have all safeties etc, lift looks good to run but doesn't. any help would be greatly appreciated
#28870 - 03/12/20 10:52 PM Re: Thyssen TCM Circa 2001 Drawbridge Evolution [Re: KoneLiftEngineer]
btw getting 49 00 code adjusting run taking more than 5 minutes any help would greatly appreciated
#28876 - 03/13/20 01:27 AM Re: Thyssen TCM Circa 2001 Drawbridge Evolution [Re: KoneLiftEngineer]
I’m wondering if this adjusting run thing has set all previous working values to “00”.
Discovered this TCM business on a google search (hope it shows);
You have this diagnostic tool?
#28891 - 03/13/20 08:52 PM Re: Thyssen TCM Circa 2001 Drawbridge Evolution [Re: KoneLiftEngineer]
FIXED = Emergency Power Active ME Board wired incorrectly went thru memory states saw that the TCM was sending Emergency Power Active to the car indicator display (which no longer works) removed ME Board lift when back on Normal.
#28896 - 03/14/20 05:19 AM Re: Thyssen TCM Circa 2001 Drawbridge Evolution [Re: KoneLiftEngineer]
Well good find! How’s EPA relate to “adjusting run”? Guess it doesn’t matter now huh?
#28898 - 03/14/20 01:21 PM Re: Thyssen TCM Circa 2001 Drawbridge Evolution [Re: KoneLiftEngineer]
When you switch over to normal an adjusting is a reset that goes to the nearest floor level, the EPA was blocking it from moving on normal.
#28976 - 03/27/20 03:56 AM Re: Thyssen TCM Circa 2001 Drawbridge Evolution [Re: KoneLiftEngineer]
heisenberg Offline
heisenberg  Offline
Anyone able to provide me with fault code list?
#28978 - 03/27/20 05:25 AM Re: Thyssen TCM Circa 2001 Drawbridge Evolution [Re: KoneLiftEngineer]
heisenberg Offline
heisenberg  Offline
Found a manual, any idea what fault: 7d 03, 7d 04 or 7d 05
Means? Drive inverter faulty?
Page Time: 0.034s Queries: 17 (0.009s) Memory: 2.7012 MB (Peak: 2.8888 MB) Zlib disabled. Server Time: 2024-04-19 08:22:12 UTC
