0 registered members (), 11 guests, and 4 spiders.
Topics6,505
Posts36,829
#30156 - 11/12/20 10:06 PM Gen2 Brake issue
Ron H Offline
Ron H  Offline
I am having a problem with a Gen2 in that it drifts up a little before taking off. I tried lengthening the brake pick time but it doesn't seem to make any difference. I know it's saving ok because when I reset the power the change is still in there, but the car is still drifting. I have set the brake pic time out to 3000 or 3 seconds with no change in the issue. As soon as the door closes the car drifts up a little then runs down, you don't notice it in the up direction as much because it's going up anyway. Anyone else experiencing something similar? It's possible we are missing a step in the saving process but I would think if it still shows our changes after we cycle the power it was saved properly.
#30158 - 11/13/20 11:20 PM Re: Gen2 Brake issue [Re: Ron H]
DripCan Offline
DripCan  Offline
Load Weight
#30162 - 11/14/20 05:27 AM Re: Gen2 Brake issue [Re: Ron H]
olugbemileke Offline
Elevatrics
Elevatrics
I am also experiencing same problem on one of the Otis gen2 comfort in my portfolio. And I know it has to do with the load as You have said @DripCan, how do we solve this problem? For someone who is new to Otis lifts
#30374 - 12/21/20 02:39 AM Re: Gen2 Brake issue [Re: Ron H]
NY Guy Offline
NY Guy  Offline
Start with swapping out the load weighing sensors to see if that works. If t doesn’t, make sure the OAD Board is wired in.
#30375 - 12/21/20 07:50 AM Re: Gen2 Brake issue [Re: Ron H]
Alex75 Offline
Alex75  Offline
Sweden
Depending on the age of the GeN2 and what kind of drive used....
OVF Drive -> ALWcomp Corr (Correction factor for internally calculated loadweighing compensation torque).
Ultra/Global Drive -> Pretorque Trim (Pre-torque values to prevent rollback)
/Alex
#33314 - 06/30/22 01:47 PM Re: Gen2 Brake issue [Re: Ron H]
Elevatrics
Elevatrics
Need help with otis gen2 bringing up DRV: <speed, 36. R=39
#33315 - 06/30/22 01:49 PM Re: Gen2 Brake issue [Re: Ron H]
Elevatrics
Elevatrics
Speed Errors, clear (shift 5)
#34529 - 01/10/23 09:09 AM Re: Gen2 Brake issue [Re: NY Guy]
Elevatrics
Elevatrics
thanks
Page Time: 0.072s Queries: 17 (0.017s) Memory: 2.7028 MB (Peak: 2.8863 MB) Zlib disabled. Server Time: 2024-04-27 04:29:08 UTC
