0 registered members (), 20 guests, and 1 spider.
Posts36,788
#30206 - 11/21/20 01:19 AM Dover 68 door operator controlled by a tk smarttec
Tweeker Offline
Tweeker  Offline
I have old dover 68 wedge operator being controlled by a TK smarttech change over board. Im getting an I FBK fault. Stopping the door from opening. It will run for several floors with no problems then it will fault out and not open. I've changed door motor and door board 6300pa6 board same fault persists. Any ideas would be appreciated!
#30208 - 11/23/20 02:31 AM Re: Dover 68 door operator controlled by a tk smarttec [Re: Tweeker]
They may be a big capacitor under the door board causing the door to not open .. it’s blue I think.
#30211 - 11/23/20 02:00 PM Re: Dover 68 door operator controlled by a tk smarttec [Re: Tweeker]
First thing I check when not getting door open is door close limit.
#30214 - 11/24/20 12:42 AM Re: Dover 68 door operator controlled by a tk smarttec [Re: Tweeker]
You aren’t going to find a capacitor under a PA6 board but did you replace the encoder with the motor?
#30235 - 11/28/20 09:37 PM Re: Dover 68 door operator controlled by a tk smarttec [Re: Tweeker]
TC7  Offline
I've had this before. I think it is too much current when holding the doors close during a run. I bet you only find it faulted with door closed. I bet manual door speed is set way too high. I never set manual speed higher than 60-75.
Page Time: 0.027s Queries: 16 (0.009s) Memory: 2.6768 MB (Peak: 2.8362 MB) Zlib disabled. Server Time: 2024-04-19 15:35:22 UTC
