0 registered members (), 14 guests, and 0 spiders.
Topics6,499
Posts36,809
#30475 - 01/13/21 02:21 AM T4 Stopping in flight
Dpless95 Offline
Helper
Dpless95  Offline
Helper
Dover T4 (duplex 5 stops) trapping people intermittently, takes about 2 hours of running to warm up and create faults. 54, 56 and 628 faults. Car tries to run 3 times then needs a TFR
I have changed
1. MC and BK contractors along with their Aux.
2. C1 contactor and Aux. (below drive main contactor)
3. Changed BKO, BKI, BK2, BK3, MCI, GL, WDPF, GL, DRDY, DE Modules
4. All of the 120v ice cube relays above brake relays.
No clue where to go with this car has been off line for 2 months now. Customer getting frustrated as well as me.
#30476 - 01/13/21 02:57 AM Re: T4 Stopping in flight [Re: Dpless95]
Master of none Offline
Had this same issue last week. Ended up being a bad IGBT. Make sure to use the heat sink compound when you replace it
#30479 - 01/13/21 01:23 PM Re: T4 Stopping in flight [Re: Dpless95]
ray oyler Offline
ray oyler  Offline
Try replacing velocity encoder.
#30489 - 01/14/21 12:14 PM Re: T4 Stopping in flight [Re: Dpless95]
NY Guy Offline
NY Guy  Offline
Looks like these faults are leaning towards losing one of the power supplies that feed the drive. Check all the power supplies on the rear of the controller for voltage and AC noise. Most likely your problem.
Good luck!
#30494 - 01/15/21 01:28 AM Re: T4 Stopping in flight [Re: Dpless95]
Looks like the 628 is the cause. I’ve never seen that one before though. How much AC voltage do you read in the bus? Could be the +/- 15v power supply, digital current regulator card, ribbon cable between DSP and current reg.
#30498 - 01/15/21 10:36 PM Re: T4 Stopping in flight [Re: Dpless95]
boomer Offline
boomer  Offline
Check the bus voltage and check it for ac could be a bad cap bank
#30597 - 02/14/21 02:31 AM Re: T4 Stopping in flight [Re: Dpless95]
E-man Offline
E-man  Offline
Jump the phase monitor and see if it goes away.
#30598 - 02/14/21 06:04 AM Re: T4 Stopping in flight [Re: Dpless95]
heisenberg Offline
heisenberg  Offline
Did you replace the relay holders as well?
#30599 - 02/14/21 07:43 AM Re: T4 Stopping in flight [Re: Dpless95]
Change the DE Module...
#30637 - 02/21/21 04:10 AM Re: T4 Stopping in flight [Re: Dpless95]
TC7  Offline
I agree with jumping out voltage monitor especially if it is one of the orange ones. Possibly this is emergency stop from CPU shutting off very briefly. TKE had a bulletin to tap on the side of it with screwdriver handle to check for flaky internal connections/contacts. These have caused a great deal of aggravation. If that is your problem then replace the component. Also make sure you have good suppressors around contractor coils.
Page Time: 0.048s Queries: 17 (0.017s) Memory: 2.7189 MB (Peak: 2.9255 MB) Zlib disabled. Server Time: 2024-04-24 13:25:16 UTC
